#31 |
#32 |
gonna get it all from suzuki spares. Just totalled it all up should come to abput £500 worth of damage if i buy second hand parts, btw thats not including the tank lol which has a dent where the handle bar went into it
#33 |
Jesus christ mate, how much!
#34 |
also i ahve a problem i can't get it back into neutral with the gear lever gone so when i start it up in gear (1st) it starts moving forward, even with clutch in a lot more than when it did before the fall, any ideas why?
#35 |
Found some headlights 110, is that expensive?
#36 |
Well the clutch is obviously not engaging, so you have knocked something, most probably the lever/cable as thats what i think you said hit the ground.
#37 |
#38 |
#39 |
Tfft, i found it, been rushing round like a mad sod. This may look good LJ, reason i'm showing you it, is cos i think you would like it...
http://www.kompo-tech.com/catalog/pr...c9527a37c45574 looks like you need these to go with... http://www.kompo-tech.com/catalog/pr...c9527a37c45574 |
#40 |
The clutch always drags a little. I reckon it's because the oil is cold and binding the plates up. Wouldn't worry about that myself.
