#31 |
The problem I have is I got Braking Wave discs fitted to the front, they have ten rivets so the four magnets will be out of alignment unlike Chris' OEM discs above which have eight rivets.
Depending on the year of bike will depend how many magnets you need, Curvy's and early Pointy's need four magnets while the later (think it starts at K6) will need eight magnets. Northwind's bike ![]() I have not tried mine yet, I have not rigged up the sensor, but Northys bike above has the rivets glued to the rear disc. As you can see they are not evenly spaced, but one full rotation send four (or eight depending on model) pulses. As to its accuracy with uneven magnets I can not comment yet. Thats because it was five, not four or eight. |
#32 | |
btw i glued my magnets in, all 8 of them and they are still there a few thousand miles later. I used one of the little hamlin sensors and it worked perfectly. |
#33 | |
Trinity
![]() my GSXR Brake discs appear to have 10 rivets. I thought they were OEM. Don't know where you/Chris got 8 rivet ones from ![]() |
#34 |
sorry i should have said on the K4/K5 GSXR front end the standard number of rivets is 8 - i'm sure it could be different on older or newer models
#35 | |
How does you speedo run with uneven magnets on the rivets, or have you done it another way? |
#36 |
Knob faced knobster
I don't Stus speedo does work, he just keeps going faster till he gets pulled by the police
2011 Speed Triple 1050 |
#37 | |
Trinity
![]() The speedo's now on the rear brake disc - not exactly on, but based on the 5 bolts with some attempt to space the 4 of them evenly. The speedo's really not bad at all as regards being unstable & running off the rear it is more accurate i.e. doesn't overread like std. |
#38 |
Aye, i have the OEM one rigged to the back wheel. Its been there since 2000 and so far has never needed to be looked at as it has been 100% reliable. I am thinking about changing the rear end, hence my switch to a sensor and magnets.
#39 |
Knob faced knobster
Right I've finally got around to buying a sensor to sort my speedo. I just need to work out what wires gto what, last one of these I did the sensor had 3 different colour wires coming from it but this one has 3 black wires, the middle one has a white trace on it too. It looks just like YCs one. Anyone care to enlighten me?
#40 |
Mine had some VERY faint trace colours on it, and I just made an educated guess from the page on greeks sig, and the sensor datasheet.
speedo problem w/ GSXR front end | catchsomesv650 | SV Talk, Tuning & Tweaking | 4 | 19-02-09 08:46 PM |
GSXR front end speedo work around | Lozzo | SV Talk, Tuning & Tweaking | 32 | 13-05-08 05:32 PM |
GSXR Stuff for an EASY curvy conversion | Stevetmanchester | Stuff Wanted | 17 | 28-04-08 08:46 PM |
GSXR front end speedo conversion sensor | svrash | Stuff Wanted | 11 | 26-01-08 11:52 PM |
For those with GSXR Front ends & USA Speedo | andyb | SV Talk, Tuning & Tweaking | 4 | 25-09-07 10:57 PM |
