Old 10-05-08, 07:34 AM   #31
LEXINGTONONE
Default Re: Calling all mechanically minded
Just to add my two pennarth, it sounds like electrical problem to me, maybe ecu, but would also change plugs, I always put a new set of iridium plugs in my bikes, especially worth doing in your case to eliminate that possibility, get a set from sparkplugs.co.uk.
Old 10-05-08, 10:24 AM   #32
neio79
Right just got back from the Dyno center and there was a problem with the bike. the first round of runs and a confused looking man came out confirming my thoughts it was lacking in power.
A bit of looking around confirmed there was a loose spade connector on one of the injectors, no3 on the bottom rail to be presise. You could see where it had not been seated properly arcing and has caused a bit of burning on the conecters.
It was pushed back in properly and run again, this time sweet as a nut, giving :105.34 BHP at the rear wheel @14,100RPM :
Needless to say i am happy at the bike producing exactly what it should and the problem known/sorted.
I was advised to go to GW and tell them what had happened and get them to replace the injector and connector under waranty!!
A big shout out to Tim Blackmore racing in Bristol, 110% recomendation from me, top bloke. He could have just said yes there is a problem get it sorted but he looked around and found out what was up, and fixed it .
Old 10-05-08, 10:57 AM   #33
Blue_SV650S
Nice easy fix sometimes it is the smallest thing isn't it!!
Did he charge you any extra for the diagnostics/fixing or just the dyno run?
Old 10-05-08, 11:02 AM   #34
neio79
nope just the 30 quid of the first set of dyno runs Top top bloke, knows his sh*t, friendly and helpful.
It places like that i would rather give my money to than GW for servicing.
Old 10-05-08, 11:06 AM   #35
Blue_SV650S
Indeed, nice to see somewhere not simply out to make a quick/easy buck
Old 10-05-08, 11:10 AM   #36
Nice one.
Bit more entertaining to ride now is it?
Old 10-05-08, 11:15 AM   #37
neio79
Nice one.
just a bit!!
Its like having a new bike again . Just got to take it to GW to replace the slightly burnt connectors. but that can be done after NW3.5. At least i know if it comes back again the likley culperit. But saying that he Seated the spade connector back in fully, herd it click in place .
Must have not been seated properly from the factory?
Old 10-05-08, 11:38 AM   #38
Blue_SV650S
Or you been hoiking too many 'mingers' and it popped off on a heavy landing?!!?
Old 10-05-08, 12:02 PM   #39
neio79
ha ha , i like to stick to the first theory
Old 10-05-08, 04:36 PM   #40
petevtwin650
just a bit!!
Glad you got it sorted in time for the nice warm weather Neio and NW3.5
I'd be surprised if it was a factory mistake. I wonder if GW's would have tinkered with the plugs and dislodged it then. As you say they have a positive click so are totally unlikely to dislodge in normal or extreme use IMO.
Help the mechanically inept! JediGoat SV Talk, Tuning & Tweaking 5 12-05-08 10:36 AM
One for the PC-minded, hard drive problem northwind Idle Banter 7 11-09-07 06:50 PM
For those more technically minded than me... andyaikido Bikes - Talk & Issues 10 07-04-07 11:39 AM
fitting a new exhaust - for the mechanically inept drumroll SV Talk, Tuning & Tweaking 12 18-05-06 02:50 PM
Three simple 2002 SV650 questions for mechanically minded... paulsemale SV Talk, Tuning & Tweaking 11 17-08-05 09:02 AM
