#31 |
It's not wrong at all but blipping the throttle smoothens the whole process out especially at higher rpm. What blipping consists of is when you go to change down, pull the clutch in, change down, give the throttle a little tweak (blip) and then let the clutch out.
What happens when you change down normally is when you pull the clutch in it starts to slow down. For example if you change down at 5000 rpm by the time you've pulled the clutch in and changed down the clutch might only be doing 4000 rpm and your engine will be doing 6000 rpm. When you let the clutch out it then has to play catch up with the engine. If you give the throttle a little blip to raise the revs during the change down process the clutch doesn't have to play catch up and makes it a smoother process. But I could be talking rubbish, the above is the way I've interpretated what blipping is. |
#32 |
The other 2 videos and a little extra one are all now up:
http://uk.youtube.com/view_play_list?p=AB682568DF0D3C85 |
#33 | |
http://forums.sv650.org/showthread.php?t=111176 |
#34 | |
Suzi perry, who's she at it with? | muzikill | Idle Banter | 78 | 31-10-13 09:57 PM |
Hunters Lodge Weekly meet up are you interested ? | fizzwheel | South & West Surfers | 10 | 30-01-09 10:38 AM |
11th May, Red Lodge to Perry | Sean_C | East Anglian Revolution | 174 | 29-05-08 03:30 PM |
Suzi Perry game | willcheng | Idle Banter | 54 | 01-12-07 11:18 AM |
Burford Travel Lodge or Little Chef? | Daz | 2005 Annual Rideout | 3 | 31-05-05 09:03 PM |
