Old 11-06-08, 10:03 AM   #31
drag
Default Re: Pre-load adjusters
Wise words there, not sure if you really need to cut the spacers tho, as the washers will sit on top, and lets say you wind out the pre load so it's at the same, or a little more than the stock caps provide.
I have new ohlins in there and, new oil also
Old 11-06-08, 10:53 AM   #32
timwilky
timwilky's Avatar
With the adjusters on minimal preload, you will find that they are about 13mm deeper into the forks than a standard cap. That is why you need to remove the 13mm. just to give you standard out the box preload settings.
Assuming you are a pie muncher, you may find the minimum sag available to high with that 13mm of extra preload pre applied
Not Grumpy, opinionated.
Old 11-06-08, 11:01 AM   #33
Jester666
How long were the spacers before you chopped them? The ones in my forks are huge!!
When the forks are unloaded and the preload caps are off they sit level with the top of the fork tubes. This makes it a PITA getting the caps back on!
Old 11-06-08, 11:04 AM   #34
drag
So essentially you are pre loading the Springs by 13mm before adding any extra preload what so ever then yes ?
Blasted thing, i'll need to get mine cut prob, i think they come up to the top of the tubes, i shall have to investigate soon.
Old 11-06-08, 11:05 AM   #35
timwilky
timwilky's Avatar
I never measured the original spacer length, simply measured the difference between the original cap depth and adjustable cap depth (13mm) scribed that round the spacer tub and hacksaw. If you look at the parts fiche you will see there are different spacers for adjustable/fixed caps.
Old 11-06-08, 11:07 AM   #36
Jester666
So just to be clear, with the forks unloaded and the caps off, the spacers should not be level with the top of the fork tubes?
Is this right? Before I go and hack bits off!!
Old 11-06-08, 11:13 AM   #37
drag
jester if you want hold off till 2 nite and i'll go measure mine it's uncut and take a few snaps also ok
Old 11-06-08, 11:18 AM   #38
Jester666
Cheers drag!
Old 11-06-08, 03:34 PM   #39
drag
My fancy adjusters are out of stock till the 16th ... grrr back to the waiting room for me
Old 12-06-08, 09:13 AM   #40
drag
Jess, sorry didnt get a chance to look last night, damn rain
Rear Shock Hydraulic Pre-load Adjusters Luckypants SV Talk, Tuning & Tweaking 5 31-01-07 05:02 PM
Pre-Load Adjusters PaulyMac SV Talk, Tuning & Tweaking 4 06-12-06 10:44 AM
pre-load adjusters jayjay SV Talk, Tuning & Tweaking 2 17-04-06 03:05 PM
Pre-load adjusters on a 2000 model The Wolf SV Talk, Tuning & Tweaking 3 15-06-05 12:22 PM
FORK PRE-LOAD ADJUSTERS ON A 'NAKED' alexb SV Talk, Tuning & Tweaking 4 21-01-05 09:19 PM
