Old 23-07-08, 09:51 PM   #31
Airwolf
Default Re: Braking my Curvy - sniff
fri. will be fine, that way i will be paid.
see you then, any probs before hand, hands full of parts let be know
Old 24-07-08, 06:43 PM   #32
toonyank
Do you have a belly pan? I didn't see it listed but I didn't see any fairing bits either.... but then I'm almost blind anyway
Old 24-07-08, 09:04 PM   #33
mikeSV
Hi... do you have the signal generator for this? - under the housing at the opposite side to the clutch housing?
Do you know if its the same as for the sv650 '99 naked?
Mike
Originally Posted by Jackhammer View Post
Howdy All -
As some of you will be aware I have decided to break my 2000 SVs for parts
Some bits have gone already and listed below are the parts left that have already been removed from the bike. ( the easy bits in other words)
If it is not listed below then it has either been sold already or it is still on the bike (like anything from the engine for e.g.) - ask away and I'll let you know ASAP.
If it turns out that the item you are interested in is still on the bike then can I please ask that you be patient for about a week to give me a chance to get the parts extracted, cleaned and posted out to you !!
Also please bear in mind that if I get inundated with PMs and queries it may take time to respond to all (especially as I am supposed to be working during the 9-5 hours - shhhhhh) - I will respond to messages, at least as best I can, in the order that they appear.
So here are your starters for 10 ..... if it says inc. P&P is included if it say exc. P&P is excluded
Battery - £15 exc
Air Filter BNC Race - £15 inc - Sold
Air Filter (Standard - 12 miles of use, yes just 12 ) - £10 inc - SOLD
Air Filter (Standard - much more use) - £5 inc
Air Filter (Standard with Snorkel Removed) - £5 inc
Bar End Weights (standard) - £5 inc - SOLD
Brake Lever - £6 inc - SOLD (that was quick Grinch)
Brake Pedal w/ spring loaded ends - £15 inc - SOLD
Carbs with Stage 1 Dynojet Kit - £45 inc. (no idea what size needles are in there - sorry) - SOLD
Center section rear (Black) - £10 inc
Chewys' Mirror Extenders - £15 inc. - SOLD
Chewys' Tank Raisers - £5 inc - SOLD
Clip-ons (1st Dibs Fast-Lad) - £25 inc
Clock Surround - £5 inc - SOLD
Clocks - £20 inc
Clutch Cover - £15 inc
Clutch Lever - £6 inc - Sold
Fabbri Double Bubble Screen in Dark Smoke - £35 inc
Front Discs (Pair) - £100 inc
Front Forks inc. Yokes - £100 Exc - First Dibs Spiderman
Front Sub Frame - £20 exc - SOLD
Fuel Tank (1st Dibs to Plug) - £45 exc
Gear Shift Pedal (w/ spring loaded end) - £15 - First Dibs Spiderman
Gear Shift Link Rod - £5 inc
Grab handle rail - £10 inc
Haynes Manual - £5 inc - SOLD
Headlight Unit for SVS - £85
LHS Front Brake caliper - £25 inc
LHS Fairing Inserts - £5 inc
LHS Foot Peg - £10 inc
LHS Heel Plate - £5 inc
LHS Pillion Peg - £10 inc
LHS Standard Rear Indicator - £5 inc
LHS Wing Mirror - £5 inc - SOLD
Loom (inc Alarm & Fobs) - £40 inc (1st Dibs Big Ape w/out Alarm @£20)
Mudguard - £35 inc
Pillion Seat - £15 inc.
R&G Crash Bung (LHS) - £10 inc
Radiator Hose - £5 inc
Rear Shock (Standard) - £20 inc
Rear Sub-Frame - £25 exc
Rear Wheel - £50
RHS Fairing Inserts - £5 inc
RHS Foot Peg - £10 inc
RHS Front Brake caliper - £25 inc.
RHS Heel Plate - £5 inc
RHS Standard Rear Indicator - £5 inc
Seat (Standard) - £20 inc
Side Stand (x2) - £10 each inc
Standard Rear Fender - £15 inc
Switch Gear - £10 each side
Tank Prop - £2.50 inc - SOLD
SV650 User Manual - £5 inc
EDIT: Items not initially listed that have already sold
Clutch Cable
Throttle Cables
LHS Foot-Peg Bracket
RHS Hanger
Gear Selector Push Rod
Radiator
Exhaust
Tyres
Clocks Loom
Braided Brake Lines
Rear Coil
Cheers all
Mike
Old 25-07-08, 08:49 AM   #34
startrek.steve
Mike
Whats a fairing Insert? is it the black bit on the inside top of the fairing?
Steve
Old 25-07-08, 08:55 AM   #35
66wilson
Hey mate what color is the bike, I see there's a few people already in front of me but am interested in the tank especially if its yellow!
Old 25-07-08, 08:58 AM   #36
toonyank
Originally Posted by 66wilson View Post
Hey mate what color is the bike, I see there's a few people already in front of me but am interested in the tank espesially if its yellow!
I thinks it's grand candy blue from his sig it says GCB
Greg
Old 25-07-08, 09:13 AM   #37
Jackhammer
Mike
I probably do have this part - i am not back home now until late next week so can't do much about getting one to you - also have no idea if its different - i will in the mean time find that out for you fella ....
Old 25-07-08, 09:14 AM   #38
Jackhammer
Greg
It is indeed Grand Candy Blue
Old 25-07-08, 09:17 AM   #39
Jackhammer
Steve
The fairing inserts are the bits that cover the Seat Bolts - There are other insets as well that cover the Wing Mirror Bolts (on the faired S versions) that - also refered to as ears i think - i have about 6 of these i think 3 - each side to sell -
and i have 2 each of the Fairing inserts
hope this helps
MC
Braking SV650S '99 r4ce_e3nd For Sale - SV's and SV related items 17 16-11-07 01:11 PM
Braking problems andyb SV Talk, Tuning & Tweaking 3 06-09-07 11:13 AM
Clunk When Braking. Alastair SV Talk, Tuning & Tweaking 6 23-08-07 05:02 PM
Last night I cried....my poor bike! Sniff Sniff aimhamilton Bikes - Talk & Issues 22 30-03-06 06:02 PM
Braking an engine svrash For Sale - SV's and SV related items 1 22-03-06 10:43 AM
