Old 31-07-08, 05:26 PM   #31
Dangerous Dave
Default Re: SV700 - Sv750 kit and fitting
Well I might be getting hold of some 700 pistons
Please avoid Holeshot!
Old 31-07-08, 05:39 PM   #32
zadar
of the shelf aftermarket pistons are around 10-15 grams heavier.
stock busa pistons are 17 grams lighter.
there are some aftermarket ones that can be lighter.
weight is not only issue with aftermarket ones.
Old 31-07-08, 05:41 PM   #33
Dangerous Dave
Thanks Zadar, that I didn't know!
Old 31-07-08, 05:43 PM   #34
zadar
that would be complete assembly,piston,rings,pin,clips.
Old 31-07-08, 05:45 PM   #35
Dangerous Dave
Ta.
Old 31-07-08, 06:43 PM   #36
So with the busa pistons, does that mean you need to work on the bottom end? i.e does just dropping them in cause balance issues?
Old 31-07-08, 06:49 PM   #37
zadar
no,you don't need to.
Old 31-07-08, 08:59 PM   #38
zadar I feel guilty for picking your brains
Curiosity question: is this because the weight difference is small or because of inherent balance in the V-twin?
Serious question: what hone do you need to take out of the SV bore for the busa pistons?
Old 31-07-08, 09:09 PM   #39
zadar
if you want to be serious about it and building race motor you would re balance whole motor again.it is correct way to do things.
in real world difference is not great enough to make it necessary ,you can get away without doing it.
you need to hone it out until you get proper clearance.clearance can be found in manual.there is range,pick number in there and go for it.engine builders pick number that they believe will give them best clearance for intended use.and you can't find 2 of them to agree
Old 31-07-08, 10:44 PM   #40
Grinch
Pardon?
Tuned SV700 engine for sale toadie For Sale - SV's and SV related items 0 07-06-08 02:38 PM
Tuned SV700 engine for sale toadie For Sale - SV's and SV related items 7 09-05-08 12:22 PM
SV700 Anyone? thedonal SV Talk, Tuning & Tweaking 9 03-12-07 11:28 AM
SV700 Thunderbike Robw#70 For Sale - SV's and SV related items 7 13-09-07 09:11 PM
SV700 Concepts DanDare Photos 20 05-08-06 05:51 PM
