#31 |
Folks please correct me if Im wrong with any of the below.
The bigger the aperture (Smaller the f number) the much shorter the depth of field. 18mm focal length will mean that the lens is capable of wide angle shots, over the standard 35mm The compact I have has 12x Zoom or theoretically a range of 450mm. That gives you an idea of what 200mm is if you work in compact numbers for focal length. For sports photography, large lenses and fast shutter times are required to stop the action. The bigger the lens, the easier it is to take shots as you dont have to be as close to the action and if you're panning on a bike, then from a further distance, its easier to control. |
#32 | |
#33 | |
Although as you say, the f number is more important as you can have the longest lense in the world, if it's not good quality your pics will look carp anyway. |
#34 | |
#35 |
#36 | |
#37 |
#38 | ||
As an example of how price increases with lens speed. Canon offer a f4.0 and an f2.8 70-200mm zoom. One is £600 and the other is £1150 rrp |
#39 | |
It's like describing tarmac as 'faster' than gravel. |
#40 |
The depth of field (i.e. the amount in focus does depend on the aperture, the wider (smaller F number) the smaller the depth of field yes but this also changes depending on the focal length of the lens also. A wider angle lens (say 18mm end) at a certain aperture will have a larger DOF than a longer focal length (say 100mm) at the same given aperture.
Most DSLRs have a smaller sensor than a 35mm film frame and as such the angle of view from a lens is different than when used on a 35mm. Generally there is a multiplication factor of around 1.5x so an 18mm lens on a DSLR will give the same angle of view as 1.5 x 18 i.e. a 27mm on a 35mm camera. A 200mm lens on a DSLR will give the same angle of view as a 300mm on a 35mm camera. For sports shots where you want to pan to give the impression of movement a slower shutter speed should be used or a fast moving vehicle will look like it's stood still. Panning example below I took using A Nikon D70, sorry it's not a bike: ![]() |
Bike camera or camera mount! | chompy | Stuff Wanted | 3 | 16-03-09 04:16 PM |
My new camera! | Alpinestarhero | Photos | 25 | 30-05-08 05:59 PM |
Questions questions...(funny noise,luggage, ferry) | the_lone_wolf | SV Talk, Tuning & Tweaking | 23 | 23-05-07 07:19 PM |
camera help | hovis | Idle Banter | 30 | 27-09-06 10:41 PM |
a few questions....well 5 questions....from a newb | flynn209 | SV Talk, Tuning & Tweaking | 12 | 10-07-06 10:56 PM |
