View Poll Results: Which shock should I go with
You've got a k5 gsxr thou shock, it won't be perfect but will be good enough 7 36.84%
You're quite heavy so you'll feel the benefit by fitting a stiffer (kwak) shock... 1 5.26%
Whatever yorkie chris suggests is the best choice... 11 57.89%
Voters: 19. You may not vote on this poll
Old 21-10-08, 12:53 PM   #31
Luckypants
Luckypants's Avatar
Default Re: the shocking truth about shock absorbers... (noob questions as asked by myself)
Racetech fork springs £80 from PDQ. These are linear. Racetech fork spring 'strength' calculator here.
HTH
Old 21-10-08, 01:05 PM   #32
ThEGr33k
http://www.k-tech.uk.com/store.php?r...2005&category=
Here are the K-tech stuff. Also linear but cheaper than racetech... Dont know how good they are but I think im going K-tech.
Hey Chris do you have tools for doing USD fork springs?
Old 21-10-08, 01:09 PM   #33
Paul the 6th
Paul the 6th's Avatar
looking for progressives to be honest. Not bothered about the fancy emulators and bits like that, just want to tighten up the front end to get rid of the dive under braking and also be able to hold a line through corners a bit more confidently. Oh and I'm a bit of a beast so it needs tightening up from standard anyway
Old 21-10-08, 01:11 PM   #34
ThEGr33k
Why progressive though?
What weight spring do you need? IMO bottoming out under braking is fixed with compression dampening. The reason I say this is I can bottom my forks out which are WAY too hard for me... The reason I can do this is because I have to run with only 1/4 compression dampening on because if I run with more they feel solid and AWFUL
So you want correct weight springs (check the link mr pants put up) and some thicker oil imo... or emulators... or Gixxer front end
Old 21-10-08, 01:15 PM   #35
Paul the 6th
because YC said they'd suit what I'm after? I can't remember what it was he said now but the advice he gave went into my ears, was processed by my brain, I thought "oh wel yeah that makes sense" and then i completely forgot lol. It was an in depth explanation which honestly made sense but I can't remember now
And I failed that mechanic test which dizzee posted... 60%. Am I a thick, nick? I'm scared. And bored senseless
Old 21-10-08, 01:18 PM   #36
ThEGr33k
No mate not thick... Just stupid.
Na peoples brains work differently, some not at all, and some like mine are just ace at everything... The point im trying to make is your special is all.
Joking ofcorse
P.S. What machanic test?
Old 21-10-08, 01:22 PM   #37
Paul the 6th
blind not stupid you, my friend, are spezial.
if you don't know what the mechanic test is, you're not worth knowing
why linears then? eh eh eh eh?
Old 21-10-08, 01:25 PM   #38
ThEGr33k
Awww I feel bad now. :'(
Because they are setup for your weight throughout the entire movement of the suspension meaning that any dive or movement is also linear and wont have any unexpected feeling or movement.
TBH I dont think youll go wrong with either.
Old 21-10-08, 01:32 PM   #39
Paul the 6th
TBH I dont think youll go wrong with either because you are absolutely crap at riding fast. Stick to royal enfields grandad.
we all know what you're trying to say g33k
i've done enough research into progressives and they sound like I'll be fine with them. I'm not exactly a hyper-sensitive rider who can jump on a bike and say "oh yeah, that extra click of rebound really helped me and look! I managed to shave half a second off my laptime!"... I'm more the sort of "yeah that feels a bit better now... not sure how or why but I like it that way".
done. yes!
Old 21-10-08, 01:41 PM   #40
ThEGr33k
done. yes!
Putting words into my mouth. Glad that is all!
Anyways im the same. I fitted my Shocker the other day went out and I was like right the back feels fine now (after a bit of playing with compression and rebound) but the front feels TERRABLE! So I played about with the rebound dampening on the front turned it 1/4 turn more and WOW It made a Huge difference!!! I was so impressed.
But try progressive shocks if that sounds more up your street and see how it goes for you. TBH I think going with thicker oil will make a bigger difference.
Many noob questions need answering? AndyL Bikes - Talk & Issues 29 08-08-08 06:27 PM
Noob with stupid questions MeatSwinger SV Talk, Tuning & Tweaking 1 03-02-08 11:47 AM
Ohlins shock questions? svrash Bikes - Talk & Issues 21 17-10-06 09:54 AM
Questions asked over terror raid...... akbarhussain Idle Banter 161 13-06-06 07:31 PM
Noob Questions jeremysilver75 SV Talk, Tuning & Tweaking 11 01-06-05 03:45 PM
