Old 03-11-08, 01:17 PM   #31
branny
Default Re: Sticky Back Brake
No. Do not use copper grease on pistons. Or indeed anywhere except for the back of the pads and things you don't want to sieze. Like pad retaining pins etc.
Just replace the fluid, chances are reservoir will be emptied by the time you've bled it up anyway.
thanks, good advice there. i need some rubber grease then.
you don't know the rear capacity do you? I have 500ml of dot 4 in my garage.
edit - and they want £8 for these seals... seems steep.
http://shop.wemoto.com/pictures.dyn?u=5834297qqq5828001
Old 03-11-08, 01:18 PM   #32
500ml plenty.
Like I say I can send you some grease, I've got some little sachets left over from yammy rebuild kits for the 400.
Old 03-11-08, 01:23 PM   #33
Sean_C
Only one passage. Seals are the same size though. I don't know for sure, think they're k1 to k3.
Old 03-11-08, 05:36 PM   #34
Dangerous Dave
If it is these callipers below you are on about they are GSXR750Y-K3 (2000-2003) and GSXR600K1-K3 (2001-2003).
Old 03-11-08, 06:14 PM   #35
Sean_C
Yep, them's the ones. I thought the 750Y-K3 calipers were 6 pots?
Old 03-11-08, 06:22 PM   #36
Dangerous Dave
No, the GSXR1000 K1-K2 were the six pots (gold) of that calliper mount design along with the GSX1400.
The TL1000R, Hayabusa, and GSXR750 SRAD had 6 pots too but of the older mount design.
Old 03-11-08, 06:30 PM   #37
Sean_C
Ah right. Thanks Dave.
Do you use your Back brake? Berlin Bikes - Talk & Issues 55 03-09-07 02:08 PM
Tyres...argh, sticky this sticky that :( ;) 21QUEST Bikes - Talk & Issues 33 01-06-07 08:55 AM
Sticky rear brake on a K4 SVeeedy Gonzales SV Talk, Tuning & Tweaking 4 24-02-07 07:20 PM
sticky back brake on yer bike Bikes - Talk & Issues 4 16-11-06 05:53 PM
Back brake not activating brake light. quikstu SV Talk, Tuning & Tweaking 3 19-06-06 04:05 PM
