Old 19-11-08, 06:21 PM   #31
fizzwheel
fizzwheel's Avatar
Default Re: Ok Geeks of Orgdom, lend me your ears
Your flux capacitor is not fluxing... you need to wind it up...
Old 19-11-08, 06:23 PM   #32
Viney
Originally Posted by Sudoxe View Post
Viney if you haven't fixed it I can pop round and sort it for you (or at least tell you where the problem is).
Dan
Cheers Dan, i might take you up on it.
Hmmm, You have just said that Verna cannot access the site she works for. RBS.
Right then, is there any VPN software installed to enable her onto company intranets. You usually then find that this VPN software is installed against an interface. I do it with my wireless interfaces so that in hotels etc I can use secure remote etc. But home/in the office I do not need to use the VPN software and hook up by traditional cable
Its a personal laptop so its been no where near RBS
Originally Posted by ukgooner View Post
It would be worth checking the hosts file to make sure there is nothing dodgy in it.
WINDOWS\system32\drivers\etc\hosts - open with notepad, it should only contain the following entries, if anything else is in there delete it, unless you know what it is there for!
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
Also worth checking the DNS settings on the wireless network device settings, make sure that they are the same as the wired adapter settings.
another possibility is Internet Explorer security settings, maybe the RBS site is in a restricted zone for some strange reason? Have you tried with another browser?
The hosts file is as yours, i have tried FF and IE and checked the DNS settings on laptop and my Own PC and both are identical that i can see.
Old 19-11-08, 06:35 PM   #33
startrek.steve
MAC Address problem?
Old 19-11-08, 06:42 PM   #34
Viney
Explain please
Old 19-11-08, 06:47 PM   #35
fizzwheel
fizzwheel's Avatar
Originally Posted by Viney View Post
Explain please
MAC address is a unique number or identifier given to a network card.
Old 20-11-08, 09:44 AM   #36
Viney
I know that, just what would the problem be
After all this, i think that the laptop is screwed anyway, as it wont turn off and i have to hold the power button down. So re-build this weekend me thinks!! again!!
Old 20-11-08, 09:46 AM   #37
Sudoxe
I doubt its a MAC address issue, if it was you wouldn't have any connectivity or an intermittant issue to different sites.
Old 20-11-08, 09:58 AM   #38
rigor
Viney, have you tried going to other banking sites on the laptop? Like hsbc.co.uk or natwest.co.uk ?
If they're not working either it would make me think of a trojan... that's probably broken, but trying to redirect you? Long shot though
Old 20-11-08, 11:47 AM   #39
Viney
Rigs, yes i can access all the major high street banks and any other site that i have tried to access, it just seems that i can no t access the RBS website via a wireless connection from Vernas laptop. As said above, it will do it on a wired connection!! Its all very odd! Anyhoo, as i say the laptop seems a bit squiffy at the moment, so going to rebuild it over the weekend and then see what happens.
Old 20-11-08, 02:52 PM   #40
Quiff Wichard's Avatar
Your just gutted you got booted of Xfactor
ha.... touche - what with Eddie izzard then this Daniel fella.. he even has same surname as me !!
Can you wiggle your ears? gettin2dizzy Idle Banter 12 13-01-09 06:56 PM
Computer geeks lend me your ears and wisdom SuzukiNess Idle Banter 2 17-12-08 10:42 AM
xbox 360 question....gamers lend me your ears.... Dappa D Idle Banter 22 09-12-08 07:09 PM
Engineers, lend me you ears... Cloggsy Idle Banter 4 19-04-07 04:43 PM
Yer Ears!! Protect 'em! Jester666 Bikes - Talk & Issues 17 24-07-06 03:02 PM
