Old 15-12-08, 09:28 AM   #31
stuballs
Default Re: Does jacking the back up work
I agree with everyone else. You absolutely have to have sorted suspension before you jack up the rear. And a steering damper would be a good idea. I raised the rear on my old carbed R6 and it was sweet but it needed a steering damper as it makes the front too twitchy.
Old 15-12-08, 11:30 AM   #32
The SV doesn't, I had SRAD750 shock at a couple of inches over stock, SRAD600 forks shorter than stock... and no tankslappers. Odd bit of a wiggle but nothing to need a damper for.
Old 15-12-08, 11:59 AM   #33
Viney
Personaly, my bike has its back jacked up, the girlfirends doesnt. I cant tell the difference at all!
Unless you start chucking lots of money at the bike (Cartridege forks, decent rear shock) i believe that there is no point in it at all.
Old 15-12-08, 12:05 PM   #34
Nah you don't have to spend much to get that
Old 15-12-08, 12:25 PM   #35
Dangerous Dave
The SV doesn't need a steering damper.
Old 15-12-08, 02:20 PM   #36
johnnyrod
johnnyrod's Avatar
20 stone comment - yeah okay smartarse.
I found in stock form mine was hard to keep on a tight line out of a bend, so speeding up the steering does help a lot, plus the better control mid-corner
Old 15-12-08, 02:38 PM   #37
SoulKiss
SoulKiss's Avatar
Not even if you jack the back up and dont adjust the front to compensate?
I DO agree with you that as stock an SV doesn't need one - but make the front too twitchy and might a damper not be a good idea?
Mind you I found the SV to steer just fine without the back end changed.
Old 15-12-08, 05:45 PM   #38
Dangerous Dave
You shouldn't consider jacking the back up without looking into upgrading the front forks first, I mentioned this in a previous post.
I have GSXR750SRAD forks, dropped 5mm, and the rear jacked up with shorter linkages with the Ohlins at its maximum length. Never had any issues, even when the 750 forks hadn't been sorted.
Steering dampers mask a poor chassis and suspension set-up, it is not a cure.
Old 15-12-08, 05:49 PM   #39
Mine would have a bit of a wiggle, but that was when I had the compression set way too hard at the back. That was with less aggressive geometry than daves (ohlins is a bit longer than the SRAD750 shock when ride height is set at top!)
The little wiggle was nothing to worry about, quite fun actually.
Odd that you could drop the yokes 5mm though, I had to have them flush to avoid the mudguard and radiator making friends at full compression. 750 forks must be a bit longer.
Old 15-12-08, 05:51 PM   #40
Dangerous Dave
They still do, well they just touch each other at full compression which I am not to worried about.
Yippee the wife may be going back to work timwilky Idle Banter 17 13-02-09 09:03 PM
first day back at work after AR08 Quiff Wichard Photos 34 10-07-08 09:37 AM
Back to work pmapp Idle Banter 37 03-01-08 10:40 AM
Mrs Ape back to work. Stig Idle Banter 41 21-05-06 09:35 PM
*Groan* Back to work tomorrow... Ping The Essex Lounge 9 26-07-05 09:39 AM
