#31 | |
![]() ![]() I suppose at the end of the day all I'm saying is that there's stuff in there that can point either way, but none of it's conclusive, everything can be explained at least 2 wats. On the other hand Suzuki say it was joint developed, but they're unreliable because that's EXACTLY what you'd say if it was just a bored and stroked 400, and you thought people might worry about reliability. So I think we just don't know. I know the crank pin isn't the same size, but that's kind of by the by... And though the engine doesn't have a 30% overbuild in it, it's not bang on the bleeding edge either. Lots of engines can't be tuned to 30% over without reliability issues, and the SV engine probably wasn't designed with major tuning in mind, not like a race rep where they know it'll go supersporting, or whatever. If you look at it as a race-base engine then you'd expect it to be stronger than it is but if you think of it as a commuter/streetbike engine, it doesn't need as much headroom.
#32 | |
![]() oil problem,crank problem,cases problem,tranny problem,cylinder problem,crank bearing problem....all this happens to stock motors,just more offten with built 650 on track. so,if it is like you said designed with 650 on mind they screwed up even more ![]() regardless of all problems it is still great little bike. |
#33 | |
Ooooooiiii!
Northy & Zadar, this is interesting, but helps our friend with his non-sparking SV1000, not even the tiniest bit! Through the mists of time I take you back to page 2 or so: Quote:
Best of luck Jambo
#34 |
Oh yeah that's what this thread was on about
![]() If the coils aren't even getting live feed then it's not a crank pickup problem, maybe interlock circuit with sidestand switch n stuff?
#35 |
I'm still trying to work out the "why"
Didnt Mr Suzuki build a frame to take an SV1000 lump ?
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#36 | |
![]() that is correct.signal for coils goes from crank sensor to ECU and than coils.is he getting power to other side of coil? |
#37 |
m4a - mp3 conversion | embee | Idle Banter | 17 | 04-06-07 09:22 AM |
700 cc conversion | CHICKENSTRIPS | SV Talk, Tuning & Tweaking | 23 | 30-08-06 02:56 PM |
once again, the svs to sv conversion... | littlewhitedaisy | SV Talk, Tuning & Tweaking | 33 | 24-05-06 03:51 PM |
GSXR front end conversion - will K5 GSXR 1000 yokes fit?? | Khewett | SV Talk, Tuning & Tweaking | 7 | 11-05-06 04:43 PM |
TL 1000 Exhaust Conversion?? | gilligan5000 | Exhausts | 1 | 16-02-05 02:57 PM |
