Old 08-12-08, 03:03 PM   #31
Default Re: air box removal questions
Nothings going to get waterlogged from the cooling system of that gixxer you posted with them is it?
Old 08-12-08, 03:06 PM   #32
pencil shavings
no
Old 08-12-08, 03:18 PM   #33
pencil shavings
http://members.optusnet.com.au/sv650...ting_Notes.pdf
I think this would shed some more light on it all?
Old 08-12-08, 03:27 PM   #34
Good guide that, but like I say there's more to making pods work properly than just changing main jets and needle heights. The extent of the changes needed I'm not sure about.
Old 10-12-08, 04:16 PM   #35
boo86
Pods arent popular over here, I'm not sure whether they're allowed in minitwins which would explain it. Zadar knows all worth knowing about it, including how to set them up.
No, you have to retain the standerd air box.
Old 28-08-19, 05:33 PM   #36
Spiral
Spiral's Avatar
have been looking for a thread about airbox mods, I have a 2000 curvy & I've noticed that the airbox inlet is only about 6mm larger than the carbs venturis, this looks rather restrictive. Has anyone cut out a larger hole or swapped the snorkel (I take it that's what the inlet tube is called) for a larger dia bit of tube ?
The bike is currently completely standard, but I have a spare engine that I hope to "tweek" over time as & when preferably for as little as possible, like finding bigger pistons that are from something else rather than the ludicrously expensive wiseco max overbore ones.
Spiral is offline   Reply With Quote
Old 28-08-19, 05:58 PM   #37
Quickest and cheapest mod to gain proper hp is to install inlet cams from a pointy.
I don't remember anyone doing any airbox mods on a curvy.
I have some pointy cams which are for sale
Old 30-08-19, 11:43 AM   #38
Spiral
Spiral's Avatar
Thanks for the reply, I need to find out which model motor my bike has first because it was swapped at 59,000 miles for another one & I'm not sure which year it's from.
How much are you wanting for the cams out of interest ?
Old 30-08-19, 11:46 AM   #39
£75 for the pair, posted, which is what I paid for them
Old 31-08-19, 07:08 AM   #40
Spiral
Spiral's Avatar
Seems like a fair price.
I need to get the bike on the road first & then start doing bits & pieces, I have the original motor that I fancy boring out & generally rebuilding at some stage ( it was burning oil hence the swap ).
Chain buffer removal requires swing arm removal :-( 2mths SV Talk, Tuning & Tweaking 1 09-07-07 09:19 AM
Questions questions...(funny noise,luggage, ferry) the_lone_wolf SV Talk, Tuning & Tweaking 23 23-05-07 07:19 PM
alarm removal fat_brstd SV Talk, Tuning & Tweaking 6 05-03-07 12:25 PM
engine removal questions tomjones2 SV Talk, Tuning & Tweaking 2 28-08-06 03:55 PM
a few questions....well 5 questions....from a newb flynn209 SV Talk, Tuning & Tweaking 12 10-07-06 10:56 PM
