Old 22-01-09, 09:25 AM   #31
TheStudent
Default Re: front sprocket
I've got 3 (from naked) up on the back, I've had 130 indicated on the naked. Yes it makes it easier to pop up, especially in 2nd. I like it, but you're turning a lot of revs on the motorway.
I never go on the motorway, very rarely on a dual carraige way, so that's not really an issue for me. So you have a 48 rear then? What size chain did you need?
Old 22-01-09, 09:29 AM   #32
I used 112 links, but it's actually a bit too long and I probably could have used a 110 as stock. Bear in mind the nekkid has 10mm extra in the swingarm. I reckon 110 links will be about spot on. (you can always order 110 and chop 2 off if needed)
Old 22-01-09, 05:37 PM   #33
embee
embee's Avatar
A faired curvey SVS is 15/44 as standard, the nekkid curvey is 15/45.
Old 22-01-09, 05:39 PM   #34
Dangerous Dave
Yes
Old 22-01-09, 06:36 PM   #35
gettin2dizzy
Nah, won't do much to the top end, since a stock SV won't hit the limiter in top on stock gearing anyway.
It will with a super-open pipe
Old 23-01-09, 08:52 AM   #36
TheStudent
I would have thought the sportier one would have the extra tooth? Or one less due to better aerodynamics?
Old 23-01-09, 11:34 AM   #37
One less for higher top speed on the S. One more on the nekkid to make it more revvy and fun in town and on tight roads.
Old 23-01-09, 04:08 PM   #38
davepreston
so can you if a naked chain and sprockets on an s or would there be a problem im on about one of the complete sets of evilbay for £70
Old 23-01-09, 04:24 PM   #39
Yes it should go on fine. However ask petevtwin how many links of chain to use, as using the 110 from the nekkid will use up 10mm of adjustment.
Old 23-01-09, 04:25 PM   #40
embee
embee's Avatar
The naked swingarm was longer, and the chain is an extra 2 links so it'll end up too long on an S. You can shorten the chain, of course.
As I said, you can just fit an extra tooth on the front with a standard SVS chain length, similarly I would suggest one tooth extra on the rear with a standard front will fit as well, though I haven't personally done that. One tooth either end is equivalent to putting roughly an extra half pitch into the chain wrap around (nominally) half the sprocket, so a quarter pitch out of each of the top and bottom chain runs, i.e. moving the wheel forward a quarter of a chain pitch (5/8" pitch or about 16mm so 4mm wheel movement).
k6 front sprocket DOM B SV Talk, Tuning & Tweaking 12 18-04-09 07:12 PM
Front sprocket 14T maviczap Stuff Wanted 5 07-11-08 08:51 PM
14t Front Sprocket svdemon Stuff Wanted 3 26-11-07 02:13 PM
14T front sprocket Quiff Wichard For Sale - SV's and SV related items 4 25-11-07 05:07 PM
Front sprocket BILLY SV Talk, Tuning & Tweaking 3 04-09-06 07:45 PM
