Old 24-02-09, 11:18 AM   #31
Default Re: Opaque oil sight glass
Off for a swim, remind me and I will post them.
You will not say "he mayyyy get away with it" after seeing them!
Old 24-02-09, 11:24 AM   #32
Alpinestarhero
i've got some images of some big ends that once lived in an audi engine, damaged after the oil pump broke. It wasn't very pretty (I did post them i think)
like I say, he maaaay get away with it, providing he
a) dosn't keep starting the bike up
b) if he really really has to use the bike he dosnt rag the poo out of it
c) and this is important - puts in some oil!!!
a bike magazine (forgot which one) had an article about running a bike with very low levels of oil in it, and although they didnt do a post-engine strip on the bike, they experianced no engine faliure (although, take the bike out and give it some load, it may have well gone pop). Modern engine oil is clever stuff, it amazes me
Old 24-02-09, 11:46 AM   #33
Luckypants
Luckypants's Avatar
It may be amazing stuff, but it is not magic. If oil is low, top it up. how many threads have there been on here about seized engines due to not checking oil? From bottom line on sight glass to the top is almost a litre of oil, a very large percentage of the stated oil capacity.
Keep the oil towards the top line of the sight glass and you engine will thank you.
Old 24-02-09, 12:25 PM   #34
dirtydog
Knob faced knobster
dirtydog's Avatar
Increase the risk? No matt, low oil is a cast iron guarantee of a total engine failure. Not "if" .... "when".
Or if it goes the other way, then the big end bearings will sieze to the crank until the shells spin, the crank will be scored, the bearing shells reduced to dust which will not do the rest of the motor much good either. One f##ked crank, zero chance of economical repair.
That's pretty much what happened to mine with low oil level
2011 Speed Triple 1050
Old 24-02-09, 05:35 PM   #35
a) dosn't keep starting the bike up Like not at all!
b) if he really really has to use the bike he dosnt rag the poo out of it Even gentle use without oil will f##k it!
c) and this is important - puts in some oil!!! JACKPOT!
Yes, stood still, upright.
So no slosh under accelerating or braking.
Good article, impressive engineering.
However, you're still saying he may get away with it and I don't like that. It's near a dead cert that if it doesn't cause failure it will reduce the life of the engine. I could not advise someone to do that!
So, I'm bored of this and we're kinda off topic. Peoples; Check your f##kin oil!!
Old 24-02-09, 06:03 PM   #36
TazDaz
Turns out the place where my bike is parked is slightly on a slant. I paddled it down the road to somewhere which is properly flat and the oil level is just below the F line.
I think it must have been everytime I was checking when it was cold it was at the house on the slant and everytime it was hot it was in the carpark at work!
So...no engine failure to report!
Old 25-07-10, 07:19 AM   #37
FishyMug
I've got the same problem with my sight glass at the moment, a slighty milky coating on the inside, and a very small amount of white gunge inside the filler cap. My bike does mainly short journeys every day (less than 10 miles), and it's parked outside all the time, but I've not got any smoke from the exhaust though. I haven't changed the oil since last autumn, so maybe it's time to change it now
Old 25-07-10, 09:49 AM   #38
yes and the filter for good measure!!!
It maybe a gasket on it way as the milky colour can be coolant
HIDding in plain sight northwind SV Talk, Tuning & Tweaking 35 30-12-08 08:38 PM
Fantastic sight and sound Ed Idle Banter 1 15-08-08 10:29 AM
Crash.NET - 250: Lorenzo out of sight. NewsBot News 0 14-10-07 04:52 AM
Sensible (web) sight this Dysparunia Bikes - Talk & Issues 5 26-02-07 12:15 AM
Operation Streetfighter: End is in sight {mo' pics!) donniej SV Talk, Tuning & Tweaking 4 12-11-04 09:57 AM
