Old 18-03-09, 08:12 AM   #31
JamesMio
Default Re: No Speedo, No Lights, No Rev Counter, No Dash.
Aaaaand it's gone again!
Same problem last night (in fairness, I should probably have tested it properly in daylight, but hey!).
I went out for a quick blip with my mate (in his shiny VX220), and about 2 miles out of town the same fuse popped - no speedo/revs/dashlights/indicators/brake lights/tail lights etc.
By sheer and utter luck, we stopped at a wee village for a drink before turning back, and started chatting to a lad in there about the problem, who introduced himself as one of the mechanics at ScotSpeed (our local Suzuki dealer!). Bonus!!
His diagnosis is as has been said on here, it'll be corroded wires somewhere along the line, because of the way the bike's designed any time it rains/gets pressure washed, water runs down underneath the tank and rots the electrics like mad.
So, with that in mind I'm planning to butcher it tonight, get all the plastics off and clean up each connector as best I can and see if I can fix it properly.
"That **** on the push-bike."
Creatomatic
Old 18-03-09, 11:02 PM   #32
plowsie
Yeah corroded wires do that, It was my dodgy wiring for my indis that did mine over.
Old 19-03-09, 08:12 AM   #33
JamesMio
I had a go at the Starter Relay last night, took it to bits and cleaned all the lovely green off them. Put it back together, reconnected the battery and now I've got nothing, completely dead.
I dare say I've loosened a wire somewhere, but I'll have another look tonight!
Grrrrr!! I hate electrics!
Creatomatic
Old 19-03-09, 04:06 PM   #34
plowsie
How funny is this, moved all my wiring out the way and hid it on Saturday, patched my puncture up to get me to Rads and waheyy my 15 has gone too
Old 20-03-09, 10:03 AM   #35
JamesMio
AAAAAARRRRGGGHH!!!!!
Finally sorted the 'Dead' problem - one of the connectors in the Starter Relay had come loose.
Rode into work to see if cleaning up the connections has fixed it, Pop - 2 miles away from home the fuse goes again.
Grrr!!! I don't think I'm going to be able to avoid stripping the lot down and going at it bit by bit (which is a bit of a nightmare with 'limited' technical expertise!)
Creatomatic
Old 20-03-09, 10:04 AM   #36
plowsie
Indicators was what is blowing mine, I'm taking it apart in the courtyard at work today. Ahh well.
Old 20-03-09, 11:19 AM   #37
To find it, you'll end up taking every piece of plastic off, cleaning everything, putting a new earth on it, etc etc. Then you'll turn it on, and start waggling, and the first set of wires you waggle will do what its not supposed to, then you'll fine tune the waggling and find one wire.......
....well we did. One solitary red wire, loose in the back of a connector block, one nip and voila, no problem any more.
I do hope you find it, its been doin my hesd in for weeks, I even resorted to riding around without the green cover on the relay and side panel, so changing main fuses was easy
So far this week it hasn;t blown once, but thenI'm waiting for it to go spectacularly when I've something important to go to....like the Peaks ride
BTW have you checked up the front end? My red wire ran the rev counter too.
Old 20-03-09, 01:33 PM   #38
plowsie
Todays Science lesson for me.
Q. If you try connecting up the indicator wires to each other, hit the indicator switch, will it blow the 15A fuse?
A. Yes, yes it will.
Was it a fair test student? Hello no Sir, its cost me £7.
Old 20-03-09, 01:42 PM   #39
JamesMio
WHAAAAT!!?!?!! Please tell me I've misread that and you've not paid £7 for a fuse?
Creatomatic
Old 20-03-09, 01:48 PM   #40
plowsie
I bought 9 fuses lol, to cover any further mishaps, never know when you might need a fuse and nowhere ever has any so I've stocked up.
no lights on dash, nadda dizzyblonde SV Talk, Tuning & Tweaking 13 28-09-08 05:16 PM
Dash lights Question Rick-UK SV Talk, Tuning & Tweaking 3 07-12-06 08:59 AM
rec counter water light?/ dash lights BIKER-DENE SV Talk, Tuning & Tweaking 1 14-02-06 06:54 PM
Dash Lights sprocket SV Talk, Tuning & Tweaking 3 01-12-05 01:59 AM
SV 99-02 dash lights sprocket SV Talk, Tuning & Tweaking 5 31-08-05 12:38 PM
