#31 | |
________ WEB SHOWS Last edited by ibshort; 19-08-11 at 12:27 AM. |
#32 |
#33 |
Thanks for all your replies.
![]() It's nice to know I'm not the only one riding unprepared for a problem. ![]() |
#34 |
#35 |
#36 | |
Essentially, thick end of the bung in first after putting rubber glue on it, into the tyre, twist the tool to remove but leave the bung there. Slice off the excess with the knife provided. Then inflate the tyre with the compressed CO2 canisters (1 canister == 10psi). Both times I've bunged my own tyre it was the rear. I then proceeded to ride for a couple of thousand miles, without much hanging about involved. I found it perfectly safe up to track speeds. After a few hundred miles, I struggled to see where the bung was, but if you looked hard you could see it. As for compounds you can squirt into the valve, like Tyre Weld. I've tried those countless times. At least half of the time they haven't sealed the tyre. Each & every time I've used tyre weld, I've stuck to below 60mph and ridden straight to a tyre shop & no further. It also makes a mess when you take the tyre off. A kit with bungs/gas for £20, or tyre weld for £7.99. You pays your money you takes your chance. ![]() EDIT: Whichever way you repair your own tyre, a certain amount of common sense is required!! |
#37 | |
I just carry a can of tyre repair and an rac card. |
tools for sale | blueto | Idle Banter | 8 | 22-06-08 02:05 PM |
Help with tools :) | sprocket | SV Talk, Tuning & Tweaking | 2 | 28-01-08 08:58 PM |
Need tools - help | skint | Bikes - Talk & Issues | 7 | 05-05-07 09:05 AM |
Tools | trudd | SV Talk, Tuning & Tweaking | 11 | 14-11-06 05:19 PM |
Hex Tools | Iansv | SV Talk, Tuning & Tweaking | 1 | 28-02-05 12:01 PM |
