Old 20-04-09, 08:10 PM   #31
zsv650
Default Re: Steering Damper for Naked Pointy???
More than nowt yah bellend.
only worth it when the original's are ****ed imo
Old 20-04-09, 08:11 PM   #32
Dave20046
Dave20046's Avatar
paid 40 quid for a set of Hels unused....if that helps
good good thought they couldn't be worth anywhere near £200 . I just paid £56 for new goodridge one's + new s/s banjos and they're worse than the ones I took off
I know, not like me - think I'm coming down with something. Ah well they're going to andyb and he's helped me out a lot so meh (and I owe him a bit of cash anyway).
Old 20-04-09, 08:12 PM   #33
They are past their best after 2-3 years depending on use, I think UV exposure degrades them too but I'm not sure about that.
Old 20-04-09, 08:13 PM   #34
zsv650
and the added tart value they bring i had a set of goodridges on my curvy looked good though i must say.
Old 20-04-09, 08:14 PM   #35
A little bit of headshake is completely different to a tankslapper.......i think perhaps your getting a little confused with which is what.
It's not a tankslapper until it knocks the pads back in the calipers.
Old 20-04-09, 09:09 PM   #36
G
Exactly and a steering damper will do little to help with a minor headshake.
6.67300 × 10-11 m3 kg-1 s-2
Old 20-04-09, 09:12 PM   #37
RingDing
RingDing's Avatar
...and the front tyre chirps as it goes lock to lock!
Don't just bolt on a damper, you're simply masking the symptoms of another issue and it will affect low speed manouverability.
Have you set the sag on your suspension, for your weight, so that the springs are operating in the correct part of their range?
Have you checked that the steering head bearings aren't worn/loose/too tight?
Have you checked front and rear wheel bearings to makes sure there is no play? And, for that matter, the swingarm bearings.
How worn are your tyres? Once mine start to square off a bit then I get a bit of a weave on if I'm on the transition from the sidewall to upright. It's nothing to worry about but if it bothers you get some new rubber.
HTH.
http://ridingalongwayslowly.blogspot.co.uk/
3x Honda C110 - phut-phut-phut
KTM Duke 690 - brum-braaaaaaa!!!!!
BSA C25 - brum-braa-braa
RD350LC Ring-ding-phut-clatter-££££££
RingDing is offline   Reply With Quote
Old 20-04-09, 09:27 PM   #38
suzsv650
Why the hell would you want a tail tidy when you can spend money on things to actually improve the bike.
Just an example of something else he could spend the money on... then go out for a **** up hahah so Lame how P I S S is blocked out.
Old 20-04-09, 09:29 PM   #39
Dave20046
Dave20046's Avatar
yup or tyres, or a nice can, or a new front end or atleast upgraded springs and a change of oil or like chris said the new rear shock.
Old 20-04-09, 09:38 PM   #40
suzsv650
Or... a new bike! you cant shine a turd!
steering damper. scottjames SV Talk, Tuning & Tweaking 13 07-03-08 01:59 PM
steering damper sv650rider SV Talk, Tuning & Tweaking 14 24-10-07 05:58 PM
Steering lock for Steering damper Sideshow#36 SV Talk, Tuning & Tweaking 8 30-08-07 11:18 PM
Steering damper BILLY SV Talk, Tuning & Tweaking 10 01-11-06 09:16 AM
Steering damper Wiltshire7 SV Talk, Tuning & Tweaking 17 26-01-05 05:38 AM
