#31 |
what is this to work out ?
Curvy With Lots Of Bits ...
But Still More To Come ![]() |
#32 |
hold on i'll get the spindle sizes..
#33 |
Whether you can use a matching SRAD wheel, or whether you need to use later and more expensive K1-K5* wheel
*K5 600 and 750. Up to K4 1000
#34 |
ok spindle size is 31.5-32mm and shank is 15mm
#35 |
wring its 25mm shank
#36 |
Yeah mine was a little below 32mm on spindle... pinch on bottom of fork will sort half a mil difference no problem if there is even a difference.
(Just remembered I measured practically on where the dust seal would sit, so a little wear here is not out of the question) What about separation between the brake discs?
#37 |
im off to bed so all we need to know is what wheel discs spindel and calipers i can use. also is there a way to use the sv speedo on the front ??
#38 |
Confirmed aye... they both take same wheel bearing (6205 2RS, 90% sure)
#39 |
what i was thinking is 130mm - 1mm for gsxr discs gives us 129 .. which would give us +1mm either side extra to get the srad wheel into the callipers...
hmmmm.. reduction of the calliper mounting faces by 1mm per side would be perfect... |
#40 |
gsxr front bearing is 25X52X15
curvy forks | husky03 | For Sale - SV's and SV related items | 5 | 29-10-08 07:10 PM |
Curvy forks wanted. | skapegoat | Stuff Wanted | 1 | 22-01-08 07:29 AM |
Gsxr Forks On Curvy | CHICKENSTRIPS | SV Talk, Tuning & Tweaking | 1 | 18-07-07 05:45 PM |
curvy sv forks fit k4 ??? | daddy_sperm | SV Talk, Tuning & Tweaking | 2 | 24-04-05 07:12 PM |
Conversion to GSXR1000 front forks ? | Powergaard | SV Talk, Tuning & Tweaking | 2 | 21-01-05 12:12 PM |
