#31 | |
Aye, I can see where it works. I think its probably a better track application when you do indeed have the right spring rate. So fair enough there ![]() ![]() By using rider on the bike sag I mean to say that you do make up a little for the spring rate being off, which would work better for a road bike where the spring is very likely to be wrong... ![]() |
#32 |
Trouble is we see alot for the road is when a rider comes in suggesting the spring rate is wrong, unless they are either end of the weight scale its often more just plainly down to a poorly setup bike overall or the fact the shock isnt working quite as it should.
Setting up especially spring rates is often a massive compromise for the road. |
#33 | |
Aye, fair enough there ![]() Does your shop by any chance rebuild Penske race shocks? |
#34 |
#35 |
#36 | |
Gr33k, you not fancy doing it yourself?
Re. spring rates and stuff, surely the spring rate is the deciding factor in whether you can get the ratio of static sag and rider sag correct? Quote:
#37 |
#38 |
I need it de-gassed not regassed
![]() I'd also argue that rider sag is more important that static sag as bikes don't ride themselves. Given the choice (which I have been with my Bimota) I set the correct rider sag even though the static sag was non existant. The tail unit is too light to get any sag. Any disparity between what rider and static sag should be and are, tells you whether the spring rate is right. If static sag is OK and rider sag is too high (large) then the spring rate is too low. If the static sag is ok and rider sag is too low (small), then the spring rate is too high. This is where static sag is useful. But in the real world it's rider sag that should be set correctly if you have to choose between the two due to incorrect spring rate. C |
#39 |
If you have no static sag then your shock will top out as soon as it extends, ie under hard braking and will then lift the rear wheel off the floor hence causing chatter under braking.
Ask how many race teams measure rider sag!. Spring rate isnt 100% down to rider weight. Overall bike geometry, rider pace and style all are just as important. |
#40 | |
But to be fair, surely anything will top out with the weight of the wheel and swing arm pulling it down and nothing to push it back. Id guess how hardh to top out depends on rebound damping. ![]() |
sv wireing guru required | davepreston | SV Talk, Tuning & Tweaking | 22 | 08-06-09 09:34 PM |
suspension guru needed - Kent area | stuballs | SV Talk, Tuning & Tweaking | 1 | 09-03-09 04:23 PM |
Suspension Issues - Need a Guru | Mr Speirs | SV Talk, Tuning & Tweaking | 26 | 22-11-08 02:19 PM |
Laptop guru required. | rictus01 | Idle Banter | 15 | 18-02-07 09:11 PM |
SV 650 s Suspension modification, help required! | Dangle_kt | SV Talk, Tuning & Tweaking | 1 | 25-12-05 05:56 PM |
