Old 05-12-09, 05:10 PM   #31
ThEGr33k
Default Re: First charge of a new battery.
Originally Posted by Spanner Man View Post
Good point Sid. I'd only ever recommend Japanese made Yuasa, Varta, or GS.
Luckily for me I have a very good Varta supplier locally. I've supplied hundreds over the years, & had very few problems with them.
Cheers.
Indeed Varta are the bollox! £50 for a 220CCA 14aH battery. Ive had it for a year and half and my god its had some hammer (in the falco). I took it to be load tested and it held fine. (had starting issues. I think it was the HT leads on their way out... Replaced them and its great again) Tested at 230CCA, so above spec
Only gets upto 12.7V though. Don't know how others are closer to 13.5v?
Old 05-12-09, 05:13 PM   #32
ThEGr33k
Originally Posted by Durbs View Post
you still living in 1978? Get a praaaaper battery. Sealed gel, plug it in, bike works.
I've heard mixed reviews with Gel. Maybe on a Sv with lower cranking requirements they are ok but for big **** crank requirements (big twins) they need something with a lot more kick (particularly the CCA part).
I may be misinformed though so if you know better please educate
Old 06-12-09, 08:14 PM   #33
ophic
ophic's Avatar
primary advantage of gel is that they will work upside down, back to front, on the side, etc. Liquid batteries don't take so well to this. However I agree with Greek that they don't tend to put out the same CCA for the battery size.
Silver SV650SK3, Fuel exhaust
Old 07-12-09, 07:31 AM   #34
Spanner Man
Any experience with dynavolt?
Good morning all.
Dynavolt batteries seem to perform pretty well. Mind you, they damn well should do for the price. They seem popular on bikes that are borderline 'under batteried' as standard. Such as 1200 V-Maxes, & some Harleys.
In my opinion they're not really worth the extra expense, over the cost of a good standard battery from a reputable maker. Also, they're no more resistant to abuse, be it intentional, (left to go flat) Or un-intentional (regulator going pop).
Cheers.
Spanner Man
Old 07-12-09, 07:26 PM   #35
Nostrils
Originally Posted by shop_addict View Post
I have an Oxford Maximiser which is kind of similar to an optimate (and only a year old or so).
I had/have the same but found that my unit lost its display fairly early on and then I believe it did not discharge and recharge the battery. In the end, despite is connected at all times, the battery failed.
I got myself a new battery before taking the bike for a service and simply followed the instructions. Empty the solution into the battery, leave to stand and then charge as necessary. All in all I would say this took about 2 hours. Enough power and time to ride to the dealers.
I decided to by myself an optimate 4, which appears to discharge the battery to a point and then recharge and maintain, very happy with it.
Incidentally, I have a Datatool 4 fitted to my SV and it definitely drains the battery to some extent if not used for a week or so, but again since the new Optimate 4 has been fitted, not problems at all!!
Good Luck
Old 07-12-09, 07:29 PM   #36
Dave20046
Dave20046's Avatar
Good morning all.
Cheers.
Thanks for that spanner man, can get them muchos cheaper than yuasa IIRC so wondered if they were worth considering.
Old 08-12-09, 07:59 AM   #37
Spanner Man
Good morning all.
I've just had a quick peruse on the net, & it seems that Dynavolt prices have come down considerably. So, it may be that they're making (or having them made) a cheaper range, in order to cash in on their name.
Cheers.
Spanner Man
Old 08-12-09, 09:01 AM   #38
Swin
Swin's Avatar
Originally Posted by tigersaw View Post
NO NO NO NO as a dealer you should know better.
The acid needs time to react with the plates, and a lot of heat and gas is given off in this time. You have to wait until the battery goes cool before sealing, else you will damage it.
The gas being given off is Hydrogen I believe, so as well as leaving the caps off before sealing it, probably best to let it sit for an hour in a reasonably well ventilated area without naked flames close by...
Swin is offline   Reply With Quote
Old 12-12-09, 07:39 PM   #39
ThEGr33k
How long should an initial charge take after adding the acid? Mine seems to be taking a long while (3 hours now and the voltage is only just getting to 14v) so my charger is still shoving in 1.2A. The voltage when I first added the acid was 12.5V. Im worried that this battery is already a ****ter.
So anyone know what it means if the charger cant get the voltage over 14V?
Old 12-12-09, 09:08 PM   #40
JediGoat
JediGoat's Avatar
Mine took about 4 hours or so (including all the faffy tests the charger does after the initial charge).
JediGoat is offline   Reply With Quote
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
battery wont hold charge taffo SV Talk, Tuning & Tweaking 14 29-12-07 08:04 PM
new battery - how to charge for first time ? Warren SV Talk, Tuning & Tweaking 18 03-12-07 09:43 PM
Do I need to charge my battery? M65 SV Talk, Tuning & Tweaking 6 15-07-05 11:20 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
