Old 10-03-10, 03:19 PM   #31
lily
Default Re: Cycle to Work Scheme
nice and warm here!
Old 10-03-10, 03:31 PM   #32
Viney
Please define warm? Where are you, Spain? Does Drew know?
Old 10-03-10, 03:41 PM   #33
lily
No Birmingham (UK) and when i say warm I mean warmer than the past couple of weeks!
Old 10-03-10, 04:18 PM   #34
Originally Posted by lily View Post
After reading the threads, you made a good choice. 700c wheels have less rolling resistance than 26in MTB wheels. To avoiud punctures, you need to keep your tyres inflated to the correct pressure, so it would be wise to invest in a track pump. Takes all the effort out of pumping your tyres up.
Invest in some tyres with a puncture proof band at some point. I'm not sure if the inner tubes with 'Slime' inside are worth the money.
But if you're worried about the thiness of road tyres, then don't. Pro riders regularly descend mountain downhill roads at suicidal speeds and rarely have a problem, its just a question of knowing the limitations of the tyres.
Get a rear mudguard if you don't fit a rack, this'll avoid the wet **** and wet stripe down your back.
Cylcle to Work Scheme: Too good to be true Jabba Idle Banter 40 01-10-09 08:13 AM
Those that cycle to work... 454697819 Idle Banter 16 11-03-09 08:45 AM
Cycle Upgrade? krhall Idle Banter 26 31-07-08 08:45 AM
new pedal bike (through the cycle to work scheme) malks Idle Banter 39 30-07-08 08:50 PM
Jersey - car or cycle Nick762 Idle Banter 9 06-06-06 11:02 PM
