Old 07-02-10, 09:00 AM   #31
Alpinestarhero
Default Re: Tips for clutch/worm drive setup
Originally Posted by madnlooney View Post
i think i need to adjust my clutch too. It seems to be grind when going from 1st to 2nd like its not fully disengaged. from 2nd onwards is find though
Do try adjusting the clutch worm drive first. Also ensure your chain tension is correct, and the chain is properly lubed. I've found that engine oil level can affect the gear changes aswell...so check this too do you have any problems engaging neutral?
Old 07-02-10, 07:50 PM   #32
madnlooney
no neutral is fine. i took abit of slack off the lever this morning so need to test it again. Ive tighten the chain but seens to slacked quickly which makes me think new chain could be needed soon
Old 09-02-10, 03:54 AM   #33
doser
I've just had a revealing couple days tweaking (fighting?) with clutch adjustment and coping with clutch drag before-and-after an oil change. I'll post up and back-reference the thread once it's live. Executive summary: topping up with a small proportion of Pennzoil API-SM (automobile) oil caused a significant drag problem - my scheduled oil change to (my usual) Motul 5100 (motorcycle) synthetic solved the problem... but I had to wait two days for the effect...
Old 09-02-10, 09:18 AM   #34
Alpinestarhero
Ah, you've found out something here...engine oil specified for cars is not suitable for motorcycles! Car oil has more friction-reducing compounds than motorcycle oil, hence you get more clutch slip, which causes more clutch heat, which can cause more clutch drag. Car oil only has to lubricate the car engine; motorcycle oil must lubricate the engine AND the gearbox AND the clutch.
Also, car oil may not be able to cope with the (potentially) higher engine speeds of motorcycle.
In anycase, if your bike engine oil is low, and all you can grab is car oil...its better than nothing, and clutches are easier and cheaper to change than a seized engine
You may want to flush out the new oil, in order to get ride of any remaining car oil and refill with fresh motorcycle oil again
Matt
Old 09-02-10, 03:32 PM   #35
doser
Dead on, Matt. And (as promised) I posted up my experiences in a separate thread:
http://forums.sv650.org/showthread.p...72#post2176372
Learning from the mistakes of others is easier than learning from your own! Provided you DO learn, that is...
Cheers,
SV Clutch Worm Drive (bearings) Dave20046 SV Talk, Tuning & Tweaking 11 25-11-09 09:36 PM
Clutch/Worm drive problem swinging_simian SV Talk, Tuning & Tweaking 2 05-08-09 01:06 PM
Clutch worm gear cammy SV Talk, Tuning & Tweaking 3 02-08-09 07:23 PM
Worm Drive tonybmw92 SV Talk, Tuning & Tweaking 15 15-08-08 08:12 PM
Clutch worm drive thing for '00 curvy Ter Stuff Wanted 1 16-01-07 04:00 PM
