Old 07-07-10, 03:47 PM   #31
Matts-Yokes
Default Re: Renthal Bar 998cc.com Conversion
Clutch cable is not required and we have never had any issues with them!
Old 07-07-10, 04:09 PM   #32
madness
Perhaps I have mine routed incorrectly.
Can anyone supply pictures of the routing?
Old 07-07-10, 05:07 PM   #33
danf1234
I would be interested to know how to route the clutch cable as well.
Old 07-07-10, 05:16 PM   #34
All i did was when you take the clip on off, you'll notice it goes through the forks and round to the lever, all i did was take it straight to the lever and not round fork leg, worked fine for me.
Old 07-07-10, 05:24 PM   #35
Take it there's no chance of the cable getting squished on full lock with it re-routed like that?
And did you do the same with the switchgear wiring?
Old 07-07-10, 05:50 PM   #36
danf1234
If you look carefully at the pictures on the website that is how they have done it on the the bike in the picture.
Old 07-07-10, 05:53 PM   #37
danf1234
Do the bars come with the little hole drilled to locate the switch gear on?
Old 07-07-10, 05:58 PM   #38
No they need drilling, you also have to remount the brake fluid reservoir.
I used the standard bracket / bolt and drilled and tapped the bars.
Old 07-07-10, 06:31 PM   #39
danf1234
Well after a proper **** day, I am having to cancel my order for the riser kit. I t will have to wait for another (better) day. MY money priorites have just rapidly changed.
Old 07-07-10, 06:33 PM   #40
Bugger
998CC.com Forum code Matts-Yokes SV Talk, Tuning & Tweaking 17 28-07-10 11:24 AM
Renthal Bar conversion BomBalong SV Talk, Tuning & Tweaking 5 05-07-10 04:35 PM
www.998cc.co.uk risers Paul1984 Bikes - Talk & Issues 15 26-06-10 06:46 AM
998cc.com comfort kit maff Idle Banter 0 04-11-09 11:24 AM
re svs renthal conversion kit markmoto SV Talk, Tuning & Tweaking 1 11-07-09 08:16 PM
