Old 15-08-11, 07:20 PM   #31
Tim in Belgium
Default Re: Which MPVs/People carriers can fit in a bike?
Max - thanks for the above.
Old 15-08-11, 07:32 PM   #32
fizzwheel
fizzwheel's Avatar
Tim - I don't know if it effects the Previa but the Jap import Emina Lucida's with the diesel engines in have a reputation of cracking cylinder heads that is well deserved. If the Diesel previa uses the same engine, might be wise to avoid diesels...
Old 15-08-11, 08:34 PM   #33
Think the Mazda Bongo/Ford Freda tin top is pretty tall, taller than most MPV's and with removable seats.
I've got a campervan version with the roof tent, go for a lot more than the tin tops.
Same problem with the Mazda cylinderhead, but most of this is down to blown head gaskets, and not stopping the engine in time. Its a combination of cast iron & aluminium which causes the head gaskets to go.
All sensible owners fit a coolant alarm to the header tank. But if looked after they can clock mega miles and cost a lot less than the VW t3 or t4
They're all imports from Japan, but parts are easy enough to find & the owners club is good
Old 15-08-11, 09:26 PM   #34
Tim in Belgium
What speed will they cruise at on the motorway and what mpg do you get?
Old 16-08-11, 07:57 AM   #35
Happily cruise at 70 if its not too tired. I've been passed by one on the motorway and it was doing 80 no problem. But then they start drinking fuel.
MPG? About 32mpg at 60mph, but avg is about 25mpg
There's sevral versions, most are automatic 4 wheel drive, but I've got a rarer 4x4 manual transmission.
They can be converted to 2 wheel drive fairly easily, which makes they less thirsty and because its an older design engine then it can run on veg oil.
http://www.igmaynard.co.uk/bongo/faqs.htm
Old 05-10-11, 09:42 PM   #36
Tim in Belgium
Anymore info on cheap MPVs that would squeeze in a bike would be appreciated
I've even heard of bikes fitting in Berlingos etc..!
Old 06-10-11, 01:50 PM   #37
m`baubz
i've recently heard of an r6 being transported to trackdays in a skoda roomster.
Old 06-10-11, 02:55 PM   #38
_Stretchie_
Large Member
_Stretchie_'s Avatar
Vito definitley, Talan from the Bike Experience uses a Vito.
I'm pretty sure that the big fella over at JHS has a Vito, not sure if it's long wheelbase but his got my BlackBird in it comfortably
How to amuze an idiot:
Look right-> <-Look Left
Old 09-10-11, 02:18 PM   #39
Tim in Belgium
Any more info on bikes in Multiplas?
Thoughts people! (new bike) lukemillar Bikes - Talk & Issues 12 16-03-09 08:38 PM
people carriers Frank Idle Banter 2 30-04-08 07:22 PM
waterproof suit carriers? - motorway commuting red5 Riding Gear 1 14-09-06 08:08 AM
Just painted my brake disc carriers..... svrash Bikes - Talk & Issues 7 03-07-06 09:50 PM
Cycle carriers tricky Idle Banter 5 18-03-06 04:19 PM
