#31 |
Wot? no kn0b comments?
#32 | ||
Creosote build up is not too much of an issue if the flue has been lined. It becomes a problem when it seeps into the brickwork of old chimneys where it can catch fire and cause a damaging chimney fire, this is the danger with creosote build up. Burning well seasoned wood will avoid this. Note that burning dirty, cheap 'house' coal has the same effect and folks who only burn coal can still have chimney fires if they do not maintain the chimney. Having the chimney swept at the end of the burning season will also help and a good chimney sweep will tell you if the material removed is 'wet' (term for creosote) and advise accordingly. Having the chimney swept again before the burning season will remove any nests etc but also any creosote that has dried out over the summer. Quote:
My burner is multi-fuel and also a boiler stove, so I burn coal most of the winter as it heats the water and runs the central heating (also have oil...) as I work from home I'm in a lot, so burning wood is not practical, I'd get through tens of cubic meters of it - coal burns longer and provides a more even heat in the radiators. In the Spring/Autumn I burn wood in the evenings, when we only need heat for a couple of hours. |
#33 |
Yes I made one but it was so funny no one got it
#34 | |
#35 |
Where do you get your wood? | Elltg | Idle Banter | 17 | 12-06-11 03:48 PM |
Anyone used Dave Wood racing? | SUPERSTARDJ01 | Bikes - Talk & Issues | 12 | 13-12-10 12:35 PM |
Wood turning | Wideboy | Idle Banter | 28 | 04-12-09 01:08 PM |
Wood you buy this? | Mighty Boosh | Idle Banter | 14 | 03-04-09 06:27 PM |
Ground Anchor in wood? | Gazza77 | Bikes - Talk & Issues | 18 | 05-07-08 09:01 AM |
