Old 20-06-12, 12:00 PM   #31
Dunn-y
Default Re: Which of these PCs should I choose?
PC arrived yesterday. Packaging was very good and PC arrived intact. Opened it up to have a look inside to make sure nothing had come loose and all I can say is that is the tidiest looking PC I have seen. All the cables were neatly tie wrapped and out the way with everything securely bolted/plugged in.
PC started straight up out the box and even had my name on the start menu. It is very quick compared my laptop. I had a quick go of Left 4 Dead 2 last night and even with a £40 Graphics Card in there it ran it at 1080p with all setting on high (no AA) averaging 40 - 50 fps which, when all you've played is console games, is very fast.
Looking forward to using this PC for other things. Well worth the money and I would recommend DinoPC if you don't mind the delivery times.
If you could only choose ONE...... Paul the 6th Idle Banter 9 13-02-10 10:02 PM
ok ok....which would you choose? Amplimator Photos 68 06-04-09 06:53 PM
Why did you choose a naked? or Why did you choose a faired? Magnum SV Talk, Tuning & Tweaking 50 18-03-09 10:47 PM
If you could have/be with anyone,who would you choose? Speedy Idle Banter 155 02-09-06 03:15 PM
What would you Choose??? Samurai Helmets 16 05-12-05 12:33 PM
