Old 12-11-13, 07:04 PM   #31
JulesW
JulesW's Avatar
Default Re: Head stock bearing life expectancy?
Quality taper roller head stock bearing for the SV 650 here for 23 quid .....
http://www.pyramidparts.co.uk/produc...ngs-kit?model=
Bikes I've owned and loved:
Bridgestone 90, Honda CB175, Suzuki GT250, Yamaha YZ125, RD350LC x2, RD350YPVS x2 & FZR600, Honda CB900F, Suzuki SV650S K6, 2014 Triumph Street Triple R
JulesW is offline   Reply With Quote
Old 12-11-13, 07:26 PM   #32
muzikill
muzikill's Avatar
Default Re: Re: Head stock bearing life expectancy?
Great link. Sk3 full kit for 23quid inc seals
Bike boot life expectancy? dyzio Boots 18 15-11-10 11:17 AM
Life expectancy of clutch/gearbox? bhd SV Talk, Tuning & Tweaking 9 08-08-10 02:39 AM
life expectancy??!! Sjbuckle83 SV Talk, Tuning & Tweaking 12 31-01-08 07:12 PM
Brake Disc Life Expectancy andyb SV Talk, Tuning & Tweaking 13 07-11-06 10:39 AM
SV 650 Life expectancy rcmark SV Talk, Tuning & Tweaking 8 04-08-05 05:43 PM
