Old 19-10-23, 07:35 PM   #31
garynortheast
garynortheast's Avatar
Default Re: Broken down with a dead battery
Thanks John, that's what i thought but just needed to check.
Blue Curvy S with over 110,000 miles and still going strong.
Old 19-10-23, 07:52 PM   #32
Ruffy
Ruffy's Avatar
Originally Posted by garynortheast View Post
I need to put a fuse in the fuseholder but not sure what rating to use. Anyone have any idea - 15a/20a/30a?
Originally Posted by admin View Post
Most bikes have a 30a, certainly the case on my last two bikes.
I agree with admin. In the standard wiring arrangement the only fuse between the reg/rec and the battery is the main fuse which is 30A.
(Unfortunately, I've never come across any information on the actual power rating of the generator itself. But it also makes sense that you want the regulator to be able to supply at least the max 'normal' current that the bikes electrical system might demand, which is up to the main fuse level in theory.)
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 19-10-23, 08:48 PM   #33
garynortheast
Thanks Ruffy.
Old 20-10-23, 07:43 AM   #34
garynortheast
Fuse in, and just need to hook the battery back up to the system now.
I'm thinking that the reg/rec has been slowly expiring for some time. I still have the Numax battery I replaced back in April, so out of curiosity I hooked it up to the Acumate charger. It came up to full charge within 15 minutes, with the multimeter showing 12.47v. Ran the meter across it again this morning and it's still reading 12.47v, so holding it's charge ok. The battery I sent back to Tayna is also ok and has arrived back with me in good condition, having tested ok in their workshop.
I now have two spare, serviceable batteries, one Numax, and one Enduroline, so if anyone is needing to replace theirs, let me know!
Old 20-10-23, 07:49 AM   #35
Craig380
Good that you found the fault, is that the first reg-rec you've had to replace on the bike? If so, it's pretty good considering the age and mileage, despite the cost and hassle of replacement!
Old 20-10-23, 08:27 AM   #36
garynortheast
It is Craig. I also think it's done well, given the propensity of these older type reg/recs for expiring. 106,000 miles - I don't think it owes me anything.
Old 20-10-23, 11:02 AM   #37
garynortheast
Hooray! I have a running bike and a properly functioning charging system.
Now, where is the sun so that I can go and ride it?
Old 20-10-23, 11:11 AM   #38
admin
John T
admin's Avatar
Old 20-10-23, 07:17 PM   #39
Ruffy
Ruffy's Avatar
Great news that you've fixed it.
Sadly I think the sun is generally about 10000miles to the south east (Sometimes I don't like what my friends in Oz tell me)
Old 20-10-23, 08:09 PM   #40
garynortheast
It was an awkward job as the small screws underneath the rear of the seat fairing are pretty manky and difficult to get at. I had to undo all the other fixings on the right hand side and carefully lift and swing the right hand plastic out of the way. It was a bit of a juggly struggle.
dead battery. metalangel SV Talk, Tuning & Tweaking 4 12-03-09 02:57 PM
Dead Battery DF! SV Talk, Tuning & Tweaking 2 01-09-08 05:36 PM
Dead Battery After Hol Staffz Bikes - Talk & Issues 3 27-07-08 06:36 PM
Dead battery sandy SV Talk, Tuning & Tweaking 2 20-07-07 07:11 PM
Possible Dead Battery? tomjones2 SV Talk, Tuning & Tweaking 3 02-03-07 05:10 PM
