Old 09-03-05, 04:24 PM   #31
MitchC
Originally Posted by ophic
Try rubbing them with Sidi Black Rains. Works for me
Is this a solvent?
Mitch
Old 09-03-05, 04:48 PM   #32
PoRk ChOp
Is this a solvent?
Mitch
No a pair of boots
Mine have wrecked my heel plates
Old 10-03-05, 12:19 AM   #33
MitchC
I knew Sidi looked familiar... It was very early here when I replied to that... I will give some solvent a try... Hopefully I don't wreck them...
Mitch
Old 10-03-05, 05:47 PM   #34
WelshWop
As said in an earlier post, use abrasive paper but start with a more corse sheet, something like P240 and gradually work up.
Save your well needed arm muscles for other rapid movement activities.
Old 10-03-05, 06:27 PM   #35
MitchC
Hey,
Thanks for the tip. I will see if I can get a corses grit wet/dry paper. Thanks,
Mitch
Old 21-03-05, 04:11 AM   #36
MitchC
Hey,
Well I finally got around to getting some coarser sand paper to sand my rearsets. I then used a Mother's Polish to shine things up. Here are some pictures of the finished product:
Mitch
Old 21-03-05, 04:42 AM   #37
ophic
ophic's Avatar
sweet. Must try that myself
Silver SV650SK3, Fuel exhaust
Old 21-03-05, 11:02 AM   #38
dclifford
I used the carbon look sheeting on the heel plates. I also put some on the top yoke too. Obviously I cut them to shape and they don't look too bad.
The polished one look very nice, but will it last?
Old 21-03-05, 08:01 PM   #39
chewy22
Look ok but next time you may wish just to remove the old anodising on the raised parts leaving the silver in between in those hard to get to and polish areas Will look a little more trick if you do it carefully. You could also opt for the drilled look I think I put to many holes in mine I have since seen one done with about 5 in each side but larger wish I had done it that way it’s to late now.
Free- heel plates+Rad edge plates diamond For Sale - SV's and SV related items 5 19-04-08 11:32 AM
Heel Plates coggers28 SV Talk, Tuning & Tweaking 8 29-07-07 03:50 PM
heel plates james160987 Bodywork 5 30-05-06 11:52 AM
heel plates......GONE kevin harte For Sale - SV's and SV related items 14 22-03-06 08:57 AM
Heel plates Couerdelion SV Talk, Tuning & Tweaking 6 23-02-05 03:50 AM
