Old 01-04-05, 06:33 AM   #31
Tris
OK
I'm new at doing this on bikes!
I checked the manual for the oil spec and bought a gallon of 10W-40 Castrol GTX.
I assume that this isn't a semi-syn but the manual doesn't say it should be!
Before I do this change can I use the GTX or wil it damage the engine/clutch
Thanks
Tris
Old 01-04-05, 07:09 AM   #32
jonboy
If it's not bike oil, it may not be wise as car oil has anti-friction additives that can make the clutch start to slip, apparently.
Old 01-04-05, 08:28 AM   #33
Clunk
I would take the oil back and exchange it for some 10W-40 semi-synthetic motorcycle oil then you know you've got the right stuff.
If you've already used the castrol it will be ok until the next oil change. We've had this discussion on here before and some one turned up some tests done by a US mag ( I think) which came to the conclusion that using car oil had no effect on the engine, clutch etc, just that it was cheaper to buy.
I still use semi-synth bike oil though.
Old 01-04-05, 11:39 AM   #34
Tris
Thanks for that.
After posting I checked Castrols' web site. They recomend the semi syn
Oh well, the car's due a service so it can get the GTX
Tris
Old 01-04-05, 05:21 PM   #35
embee
embee's Avatar
The equivalent Castrol bike oil is called "GPS", which is what I use.
Semi-synth 10W-40. Red
4 Lt Oil Semi Synthetic £12.17 TheShadow SV Talk, Tuning & Tweaking 33 14-03-09 11:06 PM
fully synthetic oil or part much difference? andygib SV Talk, Tuning & Tweaking 1 03-02-07 04:52 PM
Fully synthetic oil TC3 Bikes - Talk & Issues 3 23-01-06 03:40 PM
Synthetic oil Smiffy SV Talk, Tuning & Tweaking 5 14-05-05 04:09 PM
