Old 18-07-05, 11:42 AM   #31
will
Originally Posted by Flamin_Squirrel
Originally Posted by will
Originally Posted by northwind
You might be able to re-use the grip, but I've never had any luck removing or refitting grips... Your mileage may vary as they say.
has anyone done this mod with oxford heated grips? i don't want to knacker the heated grip, obviously.
Will.
What do you mean, as in, will you not be able to remove the grip once you've put it on?
ah, ok - to clarify, can i remove the heated grip, replace the throttle tube with the R6 one, and then put the heated grip back on. Or will the heated grip get knackered in the process of removing it?
Old 18-07-05, 11:45 AM   #32
Carsick
Will, you should be ok, but it depends how cack handed you are and how well you glued it on.
Old 18-07-05, 11:45 AM   #33
Flamin_Squirrel
Taking it off the standard SV grip caused me no problems.
Old 18-07-05, 01:26 PM   #34
Nekkid
How much difference is there in the R6 tube?
Old 18-07-05, 02:13 PM   #35
Flamin_Squirrel
For me it was the difference between reaching full throttle, and not.
Old 18-07-05, 10:16 PM   #36
If, like me, you put the grip on with a minimal amount of glue, it'll come right off. If you used a load, it probably won't It's easier to fit it to the R6 grip than the stock one as it's smoother.
Old 18-07-05, 10:20 PM   #37
BURNER
I agree, cranking it to the stops so much easier now.
Old 26-07-05, 01:50 PM   #38
sprocket
Just bought one today rang round few places thought this might be a good MOD to do before I head off to Germany, so im now gonna sort out my fuel/air mixture and do a 4000 service and install a new rear brake pad all before thursday im gonna be knackered
Old 13-07-06, 11:30 PM   #39
Razor
Most interesting...
Need a new throttle tube TightRS SV Talk, Tuning & Tweaking 2 23-12-08 10:13 AM
R6 Throttle Tube plowsie SV Talk, Tuning & Tweaking 0 19-06-07 10:21 AM
R6 Throttle Tube plowsie Stuff Wanted 3 18-04-07 02:33 PM
R6 throttle tube svryanpompy SV Talk, Tuning & Tweaking 8 08-03-07 09:17 PM
R6 throttle tube BILLY SV Talk, Tuning & Tweaking 3 13-07-06 11:14 PM
