#31 |
<--- Taxman
hey, take yer time postie, the slower you are the less work i have! btw, Cam - been done with the cloned card thingy im with the rbs bank and they were brilliant it's amazing what checks they have in place that can spot these things, they called me within a couple of hours of it going on and had already put a stop on my card, you will probably be sent out a disclaimer to sign and send back, once youve done that then the money will be put back in. Some git used my card to top up a virgin mobile payg phone in the cambridge area whilst i was 'up here' - silly people - don't they realise it can still be traced!
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. Last edited by muzikill; 20-05-07 at 11:05 AM. Reason: . |
#32 |
Pretty much all PAYG topups get routinely checked, for a long time about 40% of all credit card fraud was on phones. Nobody really gets caught for it, the hardware's available to trace an unregistered phone but it's not really practical in numbers. But most banks will tell the phone provider at least, and get the line blocked.
#33 |
I'm a music teacher, so not much use to anyone, as for the bike stuff, In the 2 months I've had my SV I have had to learn how to change a choke cable, change a clutch lever, change a gear lever, fix a leaking clutch cover and de rust the hooks under the rear seat, did i buy a lemon? Me thinks so
#34 |
music teacher??for what ??do you specialise (guitar /piano etc)or just music in general?
#35 | |
![]() I agree it does become subjective when you introduce compression and rebound but since there's no damping adjustment on an SV there's nothing to worry about. |
#36 | |
#37 |
Don't those things on top of the forks do anything? Look like little screwdriver slots.? Never touched em, but I do wonder...
#38 |
#39 |
I'm a Complex Projects Coordinator for BT. So if you want things to be coordinated don't come to me.
![]() Bikewise. I know they have two wheels. ![]() My friends tell me that I'm really usefull. Or was that useless ![]() |
#40 |
Hey all,
Not posted in awhil no www acess at home at the mo and i have to do this from work! shh!! I am a mechanical engineer (for about 6yrs!) worked for Scottish water for a while in various forms, but now i am building services which is nice! As for bike mechanics stuff! i have tinkered i.e. new exhaust, seat, tank raisers and i am gonna replace the rear subframe as its getting a but rusty, but anything else i havent tried as i dont have a garage. cheers |
