#31 |
Lol! nice one!
My mate shat his load when I cranked his cage up after the same trick, that was Duck oil penetrant spray too, bit more volatile ![]() |
#32 |
You reckon? - its definately not threaded - have maybe done 10 turns easy...but is starts to...errrr...creak, I think is the best way of describing the noise....as I turn the plug in - there is resistance, but not that much - strangely enough, if I kep turning its ok, but if I stop, then start, the initial resistance is much higher...
#33 |
#34 |
That could well just be corrosion left from the old plug, after 10 turns you would have to be a real gorrilla to bugger the threads.
Vanish? they nearly needed the fire brigade, he was stood right next to the exhaust! teehee |
#35 | |
The plug I took out was not in the best of nick (thread wise) so I think you could be right. |
#36 |
A bit more force, obviously don't stick a cracking bar on it, but you can use more than the weight of your arm, you could even be feeling the washer beginning to crush.
#37 | |
Just dont want to hurt the old girl! you done the TPS mod then? |
#38 |
Mines black and curvey, next is to cut the middle of the air filter out and increase the jet size.
(See, jets, nice brass things, fluid mechanics, none of this electrical jiggerypokery ![]() |
#39 |
F#cking hell, listen to me... you wouldnt know I'm only 18!!
Eeeeek! |
#40 |
Front spark plug problem in the wet and washing | kurtis.randle | Bikes - Talk & Issues | 15 | 04-04-09 09:16 PM |
spark plug query | appollo1 | SV Talk, Tuning & Tweaking | 3 | 29-03-09 04:52 PM |
Front Spark Plug Problems | peahead | Bikes - Talk & Issues | 12 | 03-02-08 01:17 PM |
HELP! spark plug problem | heedbaw | SV Talk, Tuning & Tweaking | 7 | 23-10-07 02:36 PM |
SPARK PLUG UPGRADE | paulsheridanz | SV Talk, Tuning & Tweaking | 3 | 19-01-05 08:11 PM |
