#31 |
#32 | |
OK Lads I think we might be jumping the Gun a little. It's entirely possible that the fluid isn't leaking out of anywhere. As brake pads wear they become thinner and the pistons move further out, 4 pistons moving out means more fluid is needed in the callipers to fill the gap, this is topped up from the reservoir (hence why it's there). Obviously if your fluid drops overnight you've got an issue, but in this case I think it's possible that the level has dropped over time. Check the pads are OK and top up as required, but obviously have a damn good check for any fluid leaking from the joins. HTH Jambo.
#33 |
Just remember. Brake fluid is also an indication on how your brake pads are doing. If there are no leaks, then there should be enougth fluid in the Resivour(I can never spell that word) to last a set of pads, soooooo, you may need new pads.
#34 | |
#35 | |
![]() EDIT: Jambo, ok, you have Xcc's of brake fluid and hit the brakes, you get a given amount of pressure applied to the discs by the pads, because of hydraulic pressure. Put more fluid in the system, and assuming you stand on the brakes just as hard (and the quality of the fluid is the same), the master cylinder would apply more pressure to the discs via the pads. I've definitely proven this to be the case with other hydraulic systems, so I don't see why brakes would be different, but happy to be corrected (internals of the master cylinder perhaps?). Last edited by Baph; 26-06-07 at 03:11 PM. |
#36 | |
#37 | |
i imagine that they would of made sure everything was tip top on it when i bought it? |
#38 | |
![]() Jambo
#39 | |
Jambo
#40 |
Very unlikely from my knowledge of DK. Fine for new bikes, a bit iffy for 2nd hand. They often pass the bike on exactly as it came in.
Advice | appollo1 | Idle Banter | 9 | 18-03-09 11:30 PM |
Advice on financial advice | wyrdness | Idle Banter | 9 | 04-12-08 12:38 PM |
advice | Quiff Wichard | Bikes - Talk & Issues | 96 | 01-04-08 05:59 PM |
MP3 advice... | Stingo | Idle Banter | 13 | 09-01-07 05:58 PM |
Hi everyone! New and looking for advice! | mario | SV Talk, Tuning & Tweaking | 16 | 23-05-05 01:08 PM |
