Old 02-11-07, 10:29 AM   #31
Spanner Man
Default Re: juddering under heavy breaking
Sadly chaps I don't do call outs, but if I did, they'd probably be the best call outs in the world!!
Hovis, you're best bet for O/E Honda bearings is David Silver spares. They specialise in genuine Honda parts, but are somewhat cheaper than your local dealer.
You will need.
91015-KT8-005 top bearing.
91016-KT8-005 bottom bearing.
53214-371-010 bottom seal.
You can re use the top seal, but are most likely to stuff the bottom one removing the inner race from the stem.
David Silver are on; 01728 833020. Double check those part numbers with David Silver, as my memory aint what it used to be, 'cause I ate a lot of beef in the eighties
If you have any hassles putting them in, give me a shout.
Cheers.
Spanner Man
Old 02-11-07, 02:19 PM   #32
andyb
Originally Posted by Welsh_Wizard View Post
fair play to your brain Spanner.. it is indeed huge with information. Shame you live in Notts 'cos I need my bike to be tweaked with shortly. Don't fancy driving down to sunny Kardiff do you to fit a zorst for me and my tail tidy ??
I could bring my bike upto Cardiff too, come on Spanner Man you know you want to relocate just for these three jobs!
Old 03-11-07, 07:45 AM   #33
Spanner Man
Morning all.
NAY NAY & THRICE NAY am I traveling to Cardiff! I have enough trouble understanding the Northern Monkeys up here. Let alone trying to decipher people who talk like they have a heavy cold!
Hovis, it's highly unlikely that adjustment will cure your steering issue, tightening the adjuster nuts will most likely make it worse. A notch is a notch!
Cheers.
Spanner Man
Old 03-11-07, 08:20 AM   #34
drefraser
Default Thread hijack attempt
Howdy,
I've just bought an '88 FJ1200 to keep me warm and comfy through the winter (and to stop my SV from being gritted).
Now the thing is it drops into corners so much you have to push the left bar hard on a left hander, and visa versa, to prevent it falling over altogether. It's got nearly new tyres set to the correct pressures. Does this sound like head bearings or is it just the way seven hundred kilo bikes handle?
Thanks,
Ewan
Old 03-11-07, 03:56 PM   #35
andyb
Looks like mine was the disc. Put a new one on today and it doesnt seem to be juddering anymore so fingers crossed it's sorted
SV 650 How Heavy? Red Herring Mini-Twins 50 17-01-08 01:35 PM
Rather heavy clutch northwind SV Talk, Tuning & Tweaking 4 14-05-06 07:46 PM
Am i too heavy? Ward8124 Bikes - Talk & Issues 23 12-04-06 05:47 PM
My New CBR6RR (img heavy) $i Photos 28 13-08-05 01:08 AM
why? is heavy metal called heavy metal pegasus The Essex Lounge 14 09-06-05 07:26 AM
