Old 11-02-09, 10:09 AM   #401
Dave20046
Dave20046's Avatar
Default Re: Bent Banana.....The SV resurrection
bloody helllllll ... bargain purchase, no wonder its worth doing up!
You know me, tight as a duck's
Old 11-02-09, 10:11 AM   #402
Dave20046
Dave20046's Avatar
Default Re: Bent Banana - The SV resurrection.
Don't drill bar, file the tab down.
Gonna do this tonight, before I do are you 100% it's a good idea lol?
My r/h switchgear's tabs snapped off and it moves about annyoing so I'm gonna attemt to put a strip of rubber in there. I suppose there's no movement on the left though.
Old 11-02-09, 04:33 PM   #403
Mine's fine like that. I think I used a bit of insulation tape to keep it in right place.
Old 11-02-09, 05:21 PM   #404
Dave20046
Dave20046's Avatar
cool I'll gets to work
Old 11-02-09, 10:29 PM   #405
Dave20046
Dave20046's Avatar
Has anyone had an issue with the clutch after fitting flatter bars? The lever touches the bar way sooner than it did on the stock set so much it doesn't even let me start the bike with the clutch pulled in as it hasn't made the connected switch. The cales are all a bit allover the place depending on which lock you've got on now too. Turn it to the right there's next to no clutch turn it to the left it's tight and lumpy. Bloody cables.
Old 12-02-09, 01:33 AM   #406
Sorry dude you're on your own there, you will just have to play with them until they work right.
Just bypass the clutch switch though it does f##k all.
Old 12-02-09, 01:43 AM   #407
Not true YC, sometimes it randomly fails and strands people. Other times, the connector comes off in crashes and strands people. And sometimes, especially with cheaper levers, it all gets a bit loose and stops engaging and strands people
(I kind of miss mine, with my cheap rubbish pattern levers there was a real trick to starting it... Nobody in my dealership or the tuner I use could start it, I could always do it, made me feel like Biff Tannen.
Old 12-02-09, 01:45 AM   #408
Heh, quite cool, but usually it just manages to leave you stranded somewhere either rough or freezing.
Old 12-02-09, 07:59 AM   #409
Dave20046
Dave20046's Avatar
Fair enough I think it Might be half lever positioning and half the cables. The clutch cable has like a curved metal tube coming from the lever end to push the cable in the right direction but ith low bars it gets in the way. Meh, I'll have a play tonight.
I've shoved a paperclip in it for now...will carry one round with me.
Old 12-02-09, 10:13 AM   #410
No, solder them. It will be a PITA for everyone on rideout if you are faffing about trying to find a paperclip!
Bent rim! phil24_7 Bikes - Talk & Issues 18 01-11-07 02:51 PM
The worlds straightest banana gazman Photos 15 19-08-07 07:21 PM
Geostationary banana over texas philipMac Idle Banter 5 01-02-07 10:21 AM
2000 W reg naked tweaked banana for sale Sloth For Sale - SV's and SV related items 0 25-06-06 12:28 AM
Photos of my new VFR Banana... chutz Photos 28 03-09-05 01:52 PM
