Old 23-03-18, 09:52 PM   #4891
admin
John T
admin's Avatar
There are lots of links to resilvering on the web using silver nitrate. How about plastic film that gets used on car windows, some of that is semi silver, stick it on the original glass?
admin is online now   Reply With Quote
Old 23-03-18, 10:39 PM   #4892
johnnyrod
johnnyrod's Avatar
Hmm ,not looked to be honest, will check it out, ta!
Old 24-03-18, 07:02 AM   #4893
Kenzie
Kenzie's Avatar
No joy Yoko, can't find the hook.
Sent from my Xperia using Tapatalk
Old 24-03-18, 05:14 PM   #4894
admin
John T
admin's Avatar
The 28mm Mitsuki turned up today. The aperture doesn't work. Checked the eBay listing, the seller did mention that but in my hurry I missed it.
So stripped it down and found that the aperture blades were gummed up. Gave them a good clean and they're working fine.... Mostly.
I lost the ball bearing for the aperture ring detents but found it by vacuuming the carpet with the little hoover. It was great to hear it clattering in the bag even though it was too small to see.
It's good to practice on something cheap.
Old 24-03-18, 06:36 PM   #4895
Kenzie
Kenzie's Avatar
I have heard that if you stretch a tight over the end of the nozzle it makes it easier to find. Are those blades pre-clean? They look oily. Can't wait to see the results.
Old 24-03-18, 07:03 PM   #4896
admin
John T
admin's Avatar
The blades had just been taken out of a bath of isopropyl. I gave them a wipe after I took this shot. I tried to lube them with shaver oil but even that was too heavy.
Old 24-03-18, 07:39 PM   #4897
Kenzie
Kenzie's Avatar
Quick turnaround in the repair. Yoko, how are you getting on with the FM?
Old 24-03-18, 08:06 PM   #4898
Kenzie
Kenzie's Avatar
Johnny, I have a spare rangefinder much somewhere. Maybe the mirror may be of use?
Old 24-03-18, 08:33 PM   #4899
johnnyrod
johnnyrod's Avatar
I'm going to look into the silvering thing first, but thanks. I'm not sure if silver itself was originally used - it is the most highly reflective, but tarnishes with light, mirrors are normally coated with aluminium as it is about 90% reflective but much more durable, even as a front coating (domestic mirrors are coated on the back to prevent damage). I had a though about re-silvering and putting a layer of tape over it, will have to have a trawl of t'internet as I can get the chemicals from work.
Old 24-03-18, 08:35 PM   #4900
yokohama
As you probably guessed, I haven't used it yet. It needs a good clean around the mount as the aperture ring is sticking and affecting the metering.
I'm off work for the next couple of weeks (perfectly timed for lousy weather) so will try to shoot off some film.
