Old 22-12-08, 03:20 PM   #41
Default Re: Busa Shock Talk
I know. But have a look and see if you can do the same trick.
Old 22-12-08, 03:26 PM   #42
plowsie
Probs nothing, will check later though.
Old 22-12-08, 03:28 PM   #43
Indeed, though actually if the shock bottom isn't threaded you can't do much. But if you run into interference issues with the nut + bolt then it's worth a look.
I could be chatting b0llocks, but it's something to bear in mind when you get t'other bolt.
Old 22-12-08, 03:30 PM   #44
plowsie
A-thanky-you-a-very-much. Will keep an eye on it when I do it.
Old 22-12-08, 03:44 PM   #45
For SRAD shock I can't remember what bolt, but you turn the bottom of the shock around t'other way so it doesn't foul the linkage.
Yah. For some reason, he wanted a GSXR thou shock in his, turned it into a lowrider
Old 22-12-08, 03:46 PM   #46
plowsie
Same happened with mine, after ****ing about with a few bits it fixed up
Old 22-12-08, 03:52 PM   #47
Mr Speirs
Mr Speirs's Avatar
A GSXR thou shock on a curvy would have made the bike really soft. Its softer than the standard IIRC.
Old 22-12-08, 04:36 PM   #48
Yeah, it was short as well. Really not a good choice, but that was what he bought, so...
Old 22-12-08, 04:41 PM   #49
plowsie
Mine feels a bit lower.
Old 18-02-09, 01:20 PM   #50
plowsie
Right then, after a few adjustments of pre-load, compression and rebound I am a happy camper.
My only little niggle is I feel a little forward biased, and in the wet I don't like that too much, but according to my fanny bands, I'm not all that forward biased, so maybe its just me.
I feel much better exiting corners, don't feel I am squatting as much.
SHOCK for a First Gen: Busa, ZX, or Something Else? youcanrunnaked SV Talk, Tuning & Tweaking 7 03-02-09 12:01 AM
Anyone got a Busa? Mej Bikes - Talk & Issues 34 30-12-08 10:10 PM
Busa shock on an '06 sv650 naked alabaster SV Talk, Tuning & Tweaking 3 25-08-06 06:18 AM
'Busa tricky Bikes - Talk & Issues 32 03-08-06 08:51 AM
busa. kwak zzr Bikes - Talk & Issues 7 07-05-06 10:41 PM
