Old 22-10-08, 07:13 PM   #41
dyzio
dyzio's Avatar
Default Re: Crash summary - advice needed
Current status.
Bike fires up every time, still on 1 cylinder.
Last start was with a new plug, didn't help, but it looks like it stopped smoking
Got some ideas what to do next (thanks Chris!), will try that in a day or two.
Have to give my ribs their well deserved rest.
hmm...
how crazy/stupid would it be to put a wee bit of petrol into the cylinder?
Old 22-10-08, 08:34 PM   #42
Find out whether the cylinder is getting it's own fuel first.
Old 22-10-08, 08:36 PM   #43
dyzio
dyzio's Avatar
Fuel on spark plug, or is there some other way?
Old 22-10-08, 08:37 PM   #44
Just sniffing the plug really. you could try add a small amount directly into the front carb throat.
Old 27-10-08, 11:59 AM   #45
dyzio
dyzio's Avatar
I've tried canking it, then refit plug, start it and over and over again.
Every time the same story.
What I started thinking about... The oil got to the airbox through the carbs, right? They haven't been cleaned, so can they be responsible for the cylinder not working?
Old 27-10-08, 12:17 PM   #46
Perhaps plugged air jets. Try put a little fuel straight into the carb mouth ... if this lets it fire then you know it's a fuelling problem.
Old 27-10-08, 12:23 PM   #47
dyzio
dyzio's Avatar
That can be done "through" the airbox?
Old 27-10-08, 12:26 PM   #48
Yes straight down the carb throat. Just a couple of drops will do, or do it with the airbox entirely removed
Old 27-10-08, 12:28 PM   #49
dyzio
dyzio's Avatar
:/ Tried that, resulted in a bang from the exhaust, and that back to normal.
Old 27-10-08, 12:47 PM   #50
When you say back to normal do you mean back to running on 1 cylinder only?
I'd say that means the front pot is getting no fuel. Have you got compressed air available?
Try a burst of carb cleaner down into the air jets with it running, might clear a drop of oil that's blocking them.
Tales of unrestriction! A summary for the future. ScottishRawker Bikes - Talk & Issues 41 17-02-10 12:46 AM
Advice Needed Please????? SAMMY650 SV Talk, Tuning & Tweaking 15 03-03-08 09:10 PM
PC Advice needed FG1 Idle Banter 11 28-12-07 04:55 PM
Advice needed please aarond SV Talk, Tuning & Tweaking 12 04-10-07 03:56 AM
Advice needed... 5v5 rider Bikes - Talk & Issues 6 04-07-06 04:21 PM
