#41 | |
#42 | |
The SV has a great chassis, only let down by the front and rear suspension. |
#43 |
I stand in awe of your superior knowledge!
I had planned on sorting my curvy's suspension out over winter. Hagon springs, thicker roil, replacement shock (ZX6R, GXSR or similar - still reseacrching). I wasn't going to jack up until I could afford a damper but now I think I'll do it and see what happens. |
#44 |
Just experience, been playing with SV's since 1999 and many other models before and after.
I personally am not a fan of the swaps, yes it is an improvement over stock but the shock was not designed and even set-up for an SV. A proper SV designed race shock is another huge step over a swapped shock. A Hagon or the cheaper Ohlins (for a Pointy) is a good upgrade at a lower cost. |
#45 |
I don't want to hijack this thread so I might post separately when the times comes. But quite simpy I can't afford a purpose built race shock so I either swap for another bike's unit or leave it as standard. Figured another bike's unit would be better if I give it the proper thought.
Cheers |
#46 | |
http://forums.sv650.org/showthread.php?t=119062 |
#47 |
i've just bought replacement dog bones to raise the rear end, for cosmetic purposes really (the sv is long and low anyway, but even more so with my fat ass perched on it!)
Does anyone have any before and after photos of jacking their bike up?, as given what i've read here, i might not do it yet unless its actually visibly noticeable. D |
#48 |
Maybe so, but nowhere near the improvement-per-£
#49 |
Darren, it's only an inch or so really. If it's looks you're after then "invest" in a different bit of plastic for the back end. You won't like it when it rains though. Have you got the preload and spring weight right, if you're somewhat corpulent?
#50 |
Yippee the wife may be going back to work | timwilky | Idle Banter | 17 | 13-02-09 09:03 PM |
first day back at work after AR08 | Quiff Wichard | Photos | 34 | 10-07-08 09:37 AM |
Back to work | pmapp | Idle Banter | 37 | 03-01-08 10:40 AM |
Mrs Ape back to work. | Stig | Idle Banter | 41 | 21-05-06 09:35 PM |
*Groan* Back to work tomorrow... | Ping | The Essex Lounge | 9 | 26-07-05 09:39 AM |
