Old 25-02-09, 03:33 PM   #41
Alpinestarhero
Default Re: Lunched
Ah, i see. But that requires more moving parts right? I can see the advantage of cooling the oil though as its gonna be further from the heat source.
Mark, where is the oil resovior on the CCM?
Old 25-02-09, 03:38 PM   #42
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: Lunched
in the DRZ it's in the frame, the CCM is basically the same bike so probably the same place, dipstick is next to the headstock
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 25-02-09, 03:39 PM   #43
Alpinestarhero
Default Re: Lunched
wow, cool, thanks guys
Old 25-02-09, 04:36 PM   #44
rigor
Default Re: Lunched
In racing cars with Dry Sumps you have to be very careful when leaving gravel traps as a stone caught in the oil pump belt would leave you with no oil circulation, and, quite quickly, no engine
Wet sumps in cars (and bikes I'd guess) are more idiot proof, it's only when you get to the level of M5's and the like that can hold sustained acceleration or cornering G that you need to be aware of oil starvation in a car.
Old 25-02-09, 04:49 PM   #45
rictus01
rictus01's Avatar
Default Re: Lunched
The DRZ engine is a double eccentric cam crank driven type , one being the circulation pump the other a scavenger one.
Old 25-02-09, 06:33 PM   #46
Airwolf
Default Re: Lunched
which listing on facebook. sv650 group?. found them...
Old 25-02-09, 09:27 PM   #47
metalmonkey
Default Re: Lunched
What a bummer! Good luck with getting the bike back working
Has any be able to establish what the yellow lumps are? If it is gold, then sweet dude
Old 26-02-09, 05:11 PM   #48
rictus01
rictus01's Avatar
Default Re: Lunched
Well had to stop as I was awaiting the rotor puller (ordered yesterday morning),Not one to waste time yesterday afternoon I recovered the seat
well guess what turned up 3 o'clock this afternoon...........yeah
got the rotor off without any problem
splitting the cases was somewhat more of a task
slowly it comes apart.
done it
the crank out
smallend stuck solid, piston locked to counter weights
down to the shed for some extra force from the vice.
got part way with this setup,
then need special tool one
moddified to special tool two
bingo
more play in the bigend than a teenager with a new PS3.
so need a new crank.
Cheers Mark.
Old 26-02-09, 05:17 PM   #49
plowsie
Default Re: Lunched
Cheers Mark.
Wow these pictures are so informative, I'm actually learning here, keep it up Mark
Old 26-02-09, 11:03 PM   #50
Default Re: Lunched
Ahhh bugger.
Looks like a 1 piece rod... can you rebuild the crank?
