Old 05-03-09, 02:43 PM   #41
Default Re: is a true underseat possible on my Racer?
M4 are good for power on modified motors. Leo vince are also very good if you're not tuning the knackers off it.
Old 05-03-09, 03:23 PM   #42
Viney
Originally Posted by lylej View Post
alreet again,
I like the central feel to an under seat can, and that its less likely to die in a spill, because ive stripped most of the lights and indys etc im going to almost completely cut off the battery box leaving a little shelf for a slimline battery for the starter.
there is no room for the pipes to come up between the shock and the swing arm so i am going to have to potentialy get a new link pipe fabricated to go up around the swing arm, and under.. like the ixils.. maybe i could just buy an ixil link pipe?
can anyone think of a reason why this wont work or cannot be done??
Lylej
As Jorge at renegade always used to say, Anything is possible, it depends on your wallet, and how much you want to cut off. Zorstec im sure will sort you out.
Old 05-03-09, 10:37 PM   #43
Robw#70
Well zorstec will certainly effect the weight distribution..................if you dont mind plenty of weight on rear wheel!!!!
Get a Hindle system, then go and see mark at MHP if you want underseat, most of the SDC bikes run underseat, if your gonna pay for it its worth gaining some hp.
Twin pipe system wont work on an sv (can per cyl) without a balance pipe, which again isn't possible when youve got one pipe out the seat and the other by the footrest.
Old 06-03-09, 12:15 AM   #44
haggis
The neatest underseat i've seen was tlr709's on svrider.com - that bike is sooo sweet.
But it uses a single swinger and I guess regs wont allow you to do that?
Old 06-03-09, 02:06 AM   #45
Renegade who make that system and "air-kit" for the SV which does what exactly
Dunno, it wouldn't be too hard to drop the balance pipe down through the swingarm, but it would require some faffing with diameters to get the volumes right.
Massive weight penalty with single siders, which defeats the object!
All comes back to the arguement, do you want a show bike or a race bike?
Zorstec do some lovely work for show bikes...
Old 07-03-09, 08:04 AM   #46
John 675
im just sticking with a stubby can most likely high level and bedone with it. the rest can goon rearsets and fairings etc.. which is more important than a poxy underseat!
thanks for the help folks!
Old 09-03-09, 02:19 PM   #47
plowsie
I got a high level stubby on mine now
Old 09-03-09, 02:23 PM   #48
John 675
What did you go for dude?
Old 09-03-09, 02:24 PM   #49
plowsie
Same as before, just got the link pipes changed over with Ady, my Viper 8 inch stubby with no packing just high level now, may have toned it down a bit I think
Twin underseat exhausts CharlieSV SV Talk, Tuning & Tweaking 7 21-07-08 05:47 PM
GT Racer DarrenSV650S Idle Banter 7 20-01-08 08:06 PM
Underseat Exhaust ???? mac SV Talk, Tuning & Tweaking 20 16-05-05 08:18 PM
Underseat? Anonymous Exhausts 2 16-03-05 05:22 PM
Underseat Exhaust schwantz fan SV Talk, Tuning & Tweaking 9 08-11-04 07:28 PM
