#41 |
After some more testing I decided to take the HID off for now for several reasons. I though I'll post my findings in case someone else picks on the thread and may be interested in a 55w HID kit for a pointy.
1. The 55W ballasts draw too much current from the standard harness, especially when run in pairs. The bulbs flash during startup and even when switching from low to main beam with the engine running suggesting the ballasts are not getting enough current through the standard harness. On top of than, they dim noticeably when the indicators are on. This suggest a relay should be used but ... 2. HIDS4U kits used 55W ballasts paired with 35W bulbs. This seem to be common practice among low end kits but some suggest that the bulbs won't last as long and they may be running hotter than 50w bulbs might do. There are 50w bulbs out there which seem to have a larger bubble with thicker electrodes but HID4U doesn't sell them. 3. The headlight housing gets really hot with the 55w setup. I mean so hot that you can't touch the headlight lens with your bare hand. This is after 5-7 minutes of idle-ing while I was trying to do some alignment. After this, I decided it is safer to take them off and put back the halogens until I can get some 35W ballasts and do more testing. 4. The solenoid mechanism used to pull the bulb in for high / low beam is soo loose that engine vibrations are transmitted to the bulb which vibrates annoyingly. I know this happens to some extent with the halogen bulbs but in the case of these bulbs, it becomes a lot more obvious and somehow irritating. So overall a bit disappointed so far. For the sake of experimentation, I'll get some 35W ballasts and see how it goes but so far a pair of good halogen bulbs seems a more sensible choice. Last edited by maxinc; 02-10-11 at 05:55 AM. |
#42 |
Just to confirm, you ordered a 55w kit and it comes with 35w bulbs?
Does your high/low solenoid use a relay system or is it directly wired from the bikes electrics? Meaning the solenoid is constantly being powered? Does the relay ever get stuck in high or low state when you are switching it? If you are going back to halogens, I would recommend the philips xtreme bulbs, the light up the road much further ahead |
#43 |
been thinking about it, I fitted a uk car projector light into a euro curvy headlight. I fitted a hid kit onto a car with projectors years back, and was very impressed, the normal h1 main beam looks pants though.
#44 | ||
![]() I ordered a set of Osrams NB but I thing I'll get some Philips Xtreme as well for comparison. Last edited by maxinc; 03-10-11 at 06:20 AM. |
#45 | |
#46 |
Ive got 3 different bosch projectors here and they all have the beam pattern cast as part of the housing.
MOT testers will pass a flat beam without the kick up to the left, but kick upto the right, as standard on the euro light wont pass. The cast part has about 2 or 3 peined over type rivets to hold it to the magnifying glass lense, but its easy enough to drill them out to swap over or remove to make a flat beam pattern. With 1 projector, the headlight is way better than it was, well dipped is, main is just a sh!t as was, lol Last edited by leebex; 04-10-11 at 08:00 PM. |
#47 | |
Amazing how much difference it made filtering down the A316 this evening, people actually moved over a bit! Didn't get flashed once either so the pattern can't be that bad... |
