#41 |
How many gears are you dropping? I always re-engage the clutch between gears and in a car always (well usuall) go down through all gears but I believe that's not what they teach now.
#42 |
usually pedals are positioned specifically to allow this, if the manufacturer has decided its a good idea. Unfortunately not with most roadgoing cars, and I've no intention of popping my kneecap off.
Silver SV650SK3, Fuel exhaust |
#43 |
aye i go through the box as well, its the proper way imo. Still were talking about cars not now bikes.... move on
#44 | |
Formerly Blue K5 with added bits Then Triumph Sprint ST with scottoiler and R&Gs & TOR exhaust Now Benelli Tornado |
#45 |
aye thats the plan
#46 | |
If you drop clutch when revs are a bit too high, nothing much untoward happens, engine revs drop down faster to match the gearbox speed. If you drop clutch too late when revs are low, engine must be span up by the gearbox, so it feels like someone slammed the brake on.
#47 |
Quick gearchanging question from me as I'm looking to get better at this too...
With downshifting from high rpms, do you need to snap the throttle completely shut every time or can you get away with slacking the throttle off a little, same as with upshifts? E.g. 8k rpm up to a corner, clutch in and thottle off/slacken throttle, change gear, blip throttle to match revs, drop clutch at right moment? Sorry to butt in on your thread AndyBrad ![]() |
#48 | |
#49 |
#50 | |
I'd go; 8k up to corner, close throttle, blip and shift simultaneously, drop clutch (throttle still closed), corner, open taps. Grin. The blip serves too functions, it matches the revs, and releases the load on the gearbox for a nice easy shift. Unless you were holding some throttle on to kill the engine braking effect to avoid sliding it out. But if you were doing it for this reason you would not be asking the question!
please help - just fallen off.....need your wisdom | rp123 | SV Talk, Tuning & Tweaking | 16 | 10-12-08 03:59 PM |
Bad Wisdom | Bear | Idle Banter | 0 | 08-08-08 02:43 PM |
Bike gear (Lidl offer) | heros | Bikes - Talk & Issues | 5 | 29-03-07 08:02 PM |
The wisdom of the MoFo's | fizzwheel | South & West Surfers | 44 | 26-01-07 07:16 PM |
Accumulated wisdom? | rictus01 | Soho Massive | 13 | 02-03-06 12:15 PM |
