Old 18-12-09, 01:44 PM   #41
zadar
Default Re: Bearing question for Curvy
http://forums.sv650.org/showpost.php...40&postcount=4
Old 18-12-09, 01:56 PM   #42
Wideboy
Evel Knievel
Wideboy's Avatar
between 4 and 5 ton, took 7 to get out but thats cos i was going the wrong way hence it breaking
05 DRZ400E
RIP hovis
Old 18-12-09, 02:01 PM   #43
Wideboy
Evel Knievel
Wideboy's Avatar
froze the yoke and heated the stem when fitting, if i've done it wrong i cant see ot coming apart it extremely tight but them im no engineer
05 DRZ400E
RIP hovis
Old 18-12-09, 02:01 PM   #44
zadar
Gavin how much pressure did yours need to fit in the yoke?
Chris,
It is common practice to press stem in to yoke and bearing in same time. You put race on press, than yoke on top of race and than you press stem in both at same time. When you do this you will get that resistance needed to press it in but you can't tell if stem is pressing in both or just one.
Old 18-12-09, 02:14 PM   #45
You sure it wasn't other way around?
Old 18-12-09, 02:22 PM   #46
ok.. zadar made a comment about all gsxr stems being the same from 96 onwards. what about pre 96 lets say gsxr 750 1993 what are they like. is it possible for widebhoy to have got an earlier lower tipple by mistake?
Old 18-12-09, 02:34 PM   #47
1993 is same bearings, so I presume same stem as all the older stuff, slingshots, slabsides etc. They take the same bearings as the curvy.
But the water cooled slingshots have one big lump of a steering stop in the middle, the one widepants has in pics previous shows a lockstop each side, which is SRAD.
Either it is wrong, or snapping the bottom end off it expanded it slightly.
Old 18-12-09, 02:47 PM   #48
CheGuevara
So you constricted the yoke and expanded the stem? That might explain the apparent tight fit going back together.
If it was me - I'd be inclined to take it apart and make sure it's right, given it's such an important assembly.
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 18-12-09, 03:09 PM   #49
zadar
He has srad triple.
All gsxr stems share lower bearing with sv. Pre 96 share both, lower and upper with sv.
All gsxr 96 and up share upper and lower bearing.
Pointy shares upper and lower with 96 and up gsxr's.
Old 18-12-09, 03:25 PM   #50
are the stems from a srad and curvy hollow?
TWF bearing for curvy f/e swap. chakraist SV Talk, Tuning & Tweaking 11 08-07-09 09:52 AM
head bearing nut question ? bad-sv650 SV Talk, Tuning & Tweaking 21 27-01-09 10:59 AM
Hello (and a question on curvy cam swaps) Spoon SV Talk, Tuning & Tweaking 25 18-04-08 01:19 PM
Is it my steering bearing? Lakes_Puma SV Talk, Tuning & Tweaking 16 19-07-07 10:27 AM
headlight Question curvy Quiff Wichard SV Talk, Tuning & Tweaking 11 28-04-07 07:27 AM
