#41 |
Keep revs high, clutch slipping and feather the rear brake as required. Keeping the revs high is the key to it, flywheel spinning acts like a gyro. Really is easy.
#42 | |
Other things that you don't pull off so well may not end in the same pretty result. If my brain wants me to do one thing, and my motor co-ordination fails me, I go back to it until I can do it - I won't leave it just because there is another means to the end. |
#43 | |
As Lozzo said earlier in this thread, its a meaningless routine designed by people who probably have never rode a bike. |
#44 |
Yeep, but if I couldn't physically do u-turns and others could I wouldn't really settle for anything less. If they can do it, so I should be able to also.
I see what you're saying, its hardly the most important/useful routine, but if I couldn't do 'em due to incompetence/lack of control then yeh that would be an issue - not because I wanna do U-turns, but because it would peev me off til I got the hang of it. |
#45 | |
#46 | |
http://en.wikipedia.org/wiki/Gyroscope It is also very light compared to a motorbike, or rider. High revs let you control your speed with the clutch, which is often easier than low revs . Rear brake is also very helpful, the clutch can be slipped and very slowly drag the bike against the brake, this seems to me to reduce the effect of throttle/clutch input, meaning ham-fisted application won't make you unstable. I can perform a low-speed turn on a bicycle with no flywheel. |
#47 |
It can, it just has to haul the mass of a bike with it. How much difference it makes I have no idea. I doubt anyone would push their bike over at different revs to test it.
Silver SV650SK3, Fuel exhaust |
#48 |
3 point turn on the SV was a bit pooy on some roads, I was taught high revs, gentle on the clutch and a bit of back brake, its equally faster in residential areas to make use of the path, you pay for it so why not use it.
#49 |
Dont think its been mentioned but having got the hang of it pretty well on my DAS, I found this makes a huge difference:
Pull away in a straight line for a couple feet to get your balance first, going into a uturn without being properly balanced at low speed is a recipe for disaster ![]() |
#50 |
a lot of very good advice above.
how about finding a MC training school like the one you used to get your lessons and give them some cash for a days training of 'u turns' on different bikes till you have it nailed. that way you have an instructor to show you your faults plus if your going to drop a bike your going to drop their bike. well worth the cash. |
Curvey SV turn signal/side stand relay diodes | Zombie Jesus | For Sale - SV's and SV related items | 0 | 03-05-10 07:53 PM |
Bike wont turn over. | pudsey | Bikes - Talk & Issues | 3 | 10-04-10 01:09 PM |
damaged sv wanted to turn into race bike | rude | Stuff Wanted | 0 | 22-12-09 08:59 PM |
Bike Failed MOT | neio79 | SV Talk, Tuning & Tweaking | 34 | 13-09-07 05:29 PM |
Help bike wont turn over | aarond | SV Talk, Tuning & Tweaking | 6 | 06-05-07 03:08 PM |
