Old 31-07-10, 11:44 AM   #41
Rob969
Default Re: Rear shock suggestions - I'm overwhelmed.
Well the posty just delivered this today. 2005 zx10 shock in mint condition just got to wait for the bolt and nut from wemoto before i can fit it.
Old 02-08-10, 06:39 PM   #42
Rob969
I've started sorting my bike ready to swap the shocks over stripped the rear body work and removed the battery and also loosened the top bolt of the shock (which was a right B*****D) but which bolt on the swingarm linkage is it best to take off to access the bottom shock bolt front or back, or doesn't it matter. Got a couple of weeks off work with a fractured arm so thought i might as well put the time to good use whilst i can't ride the bike.
Old 02-08-10, 06:46 PM   #43
Rob here is the guide i'll be using. Its for the ZX6 but the stripping and assembly process is the same
http://forums.sv650.org/showthread.php?t=113667
Old 02-08-10, 06:58 PM   #44
Rob969
Cheers done everything up to that point. Just make sure that you come to change it you loosen the bolts off a little before lifting the bike up took an awful lot of elbow grease to move the top one.
Old 02-08-10, 10:41 PM   #45
Dogbone ones are the usual culprit.
Old 02-08-10, 11:59 PM   #46
barwel1992
my dog bone bolts were stuck solid rounded both ends of with breaker bar in the end i had to cut them off.
at some point im going to drop the whole linkage and clean and greace it again now that i have proper greace
Old 03-08-10, 09:46 AM   #47
whts the best. Red rubber or copper slip
Old 03-08-10, 09:59 AM   #48
what for
Old 03-08-10, 10:06 AM   #49
Rob969
i think he means for the dogbone linkages
Old 03-08-10, 10:17 AM   #50
TamSV
TamSV's Avatar
In that case, neither! You could use general purpose grease. I think I used bearing grease on mine.
Rob, while you're at it you may as well drop that linkage out (where the bottom of the shock attaches) and give it a good clean and regrease. Mine was pretty grim.
Push the metal spacers out, clean everything up with a rag and press new grease into the bearings.
Rear shock Icanopit SV Talk, Tuning & Tweaking 17 29-12-09 09:15 PM
636 rear shock drag Stuff Wanted 0 31-07-09 10:18 AM
Poor rear brake, suggestions? Smoggy SV Talk, Tuning & Tweaking 14 26-02-09 07:09 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
new rear shock mc_phers0n SV Talk, Tuning & Tweaking 0 10-05-07 04:00 PM
