Old 15-10-10, 01:31 PM   #41
flymo
flymo's Avatar
Default Re: FREE Footpeg Raising/Lowering Plates..Be Quick!
Originally Posted by Matts-Yokes View Post
Maviczap and flymo, thanks for that. Leave it with me and i will sort out a design, maviczap can you send me the old ones you have.
Flymo, is it 56mm on the pointy as maviczap has sorted the curvy for me.
2 Members are getting free plates. Thanks
I will PM you when done
Case closed!
Yes, measured on a K3. The hole spacing is the same for all models of pointy but as I said the rear subframe is in a lower position from K4 onwards. The K3 had a unique subframe.
Old 15-10-10, 02:26 PM   #42
flymo
flymo's Avatar
Do these plates come with longer gear selector rods?
Old 15-10-10, 02:58 PM   #43
davepreston
matt went out lastnight to measure the sizes for the thou and noticed something
due to the thou having duel zausts there imho is an issue using plates cos of the routeing of the pipes,
id say it would be best if i brought the bike to you for you to work out a way around the problem
hth
Old 15-10-10, 03:09 PM   #44
hth
DP the plates I had were for 650 & the thou, so there shouldn't be any issue.
Might be the case if you've got non standard link pipes like I have
Old 15-10-10, 03:23 PM   #45
davepreston
no mate the thou is a bolt on zaust change so standard pipeing on mine , but there is a space issue with moving the lever assembly due to the way the zaust is routed under and then behind the assembly
Old 15-10-10, 03:34 PM   #46
davepreston
best pic i could find
see how close the pipe runs to the rear of the assembly, its more obvious on the left hand side
Riders Footpeg Brackets & Restrictor Plates chris8886 For Sale - SV's and SV related items 3 11-02-11 01:39 PM
FS: footpeg lowering kit the red devil For Sale - SV's and SV related items 0 22-10-09 08:09 PM
Quick. I have a morning free... Stig Thames Valley 11 24-03-09 11:55 PM
Free- heel plates+Rad edge plates diamond For Sale - SV's and SV related items 5 19-04-08 11:32 AM
Curvy SV footrest raising plates, £15 northwind For Sale - SV's and SV related items 3 15-10-07 10:05 PM
